Old 03-30-2012, 10:43 PM   #21
Drinkin beer on the beach
Rod Johnson's Avatar
Originally Posted by baldy View Post
And the answer is....
Wait for it....
A strap wrench!!
Snap-on
BLPSTWR4, Wrench, Strap, 4"
Even a Snap On is only $15.
I couldn't get my strap wrench to hold it tight enough
I put my belt around the ball and clamped in the pipe side of my bench vise and cranked on the nut with a breaker bar.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 03-31-2012, 07:09 AM   #22
MtnGuy's Avatar
Thanks for all of the ideas. Heading to Lowe's today to either get a pipe wrench (need 1 of those around the house, anyway) or see if they might have a strap wrench.
Old 03-31-2012, 07:53 AM   #23
Mountainmanbob's Avatar
Originally Posted by mtnguy View Post
strap wrench.
strap wrench as shone
might not be the best tool for the job
hard to beat a pipe wrench
grip that ball right
should be minimal scratching
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 03-31-2012, 08:32 AM   #24
sherdep's Avatar
the ball sould have two flat places at the base across from each other where you can put a adjustable wrench on it and then put a put a piece of cloth on the end of the wrench and let it rest on the bumper or hitch if possible while turning the nut.
I would install the reciever upside down so the nut is on top and the ball is on the bottom and tighten the ball and nut that way.
you may need an extra hand to hold the wrench and or ball until it gets tight.
I doubt a strap wrench is going to have enough strength the hold it in place
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-31-2012, 08:53 AM   #25
MtnGuy's Avatar
This ball has a completely round base.
I have the WDH installed 1 quarter turn in the receiver so that I can push down to tighten the nut. That way, I can stand on a scale and get the proper torque on the nut.
Old 03-31-2012, 09:18 AM   #26
baldy's Avatar
You look at the task and think it will be easy but it turns out to be the biggest pain ever. Every time I touch one I curse it!!
I have used a big pipe wrench only because nothing else would work. Usually when trying to remove it though.
Soft jaws in the chuck of the vise would work to clamp onto the ball.
Good luck!
baldy is offline   Reply With Quote
Old 03-31-2012, 11:32 AM   #27
Herk7769's Avatar
And the answer is....A strap wrench!!
Snap-on BLPSTWR4, Wrench, Strap, 4"
I am thinking you never really tried this on a trailer hitch ball...
HAM CALLSIGN - KC3FFW
Old 04-02-2012, 02:47 PM   #28
MtnGuy's Avatar
Update. The strap wrench wouldn't quite hold the ball enough. I ended up putting the strap wrench on the ball, and a pipe wrench on the base, and had the missus do the torquing with the cheater ball. After a little filing the grooves that were made by the pipe wrench, all is good.
Old 04-02-2012, 02:54 PM   #29
I always ground or cut flats on the base and put it in a vise and tightened with an 18" cresent and cheater bar. Once tight, tack welded on the flats. Always drilled a hole in the threaded portion of the shank, below the nut and inserted 1/8" cotter pin.
Old 04-02-2012, 03:01 PM   #30
MtnGuy's Avatar
No room for that. With an 1 1/8" platform, the nut and washer, that takes up pretty much all of a 2 5/8" shank. Torquing to 450 lbs., and rechecking after a couple of uses, the nut backing off should not be a problem.
