Old 04-12-2019, 12:15 PM   #1
swj
Timbren Suspension Enhancement System
F150 SuperCrew, max tow, 20 inch wheels, Fastway E2 WDistribution Hitch, 6000 lbs trailer(dry), thinking about upgrading truck with Timbren SES?
Has anyone done this? Results?
swj is offline   Reply With Quote
Old 04-12-2019, 12:18 PM   #2
DieselDrax's Avatar
What are you trying to address/fix? It will be helpful to know why you want to add them so we can tell you if they will help or not.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is online now   Reply With Quote
Old 04-12-2019, 01:11 PM   #3
I have them and love them. I pull a 30í fifth wheel with my F150 and it is much more stable plus very little squat.
No airbags to leak or fill.
spydunks is offline   Reply With Quote
Old 04-12-2019, 01:21 PM   #4
Sumosprings is an option also.
AZ Pete is online now   Reply With Quote
Old 04-12-2019, 01:25 PM   #5
swj
Truck squats alot when I hitch to trailer, WD Hitch brings the back of the truck back up. Thinking the less work the WD hitch has to do the better. Better towing, less sway?
Old 04-12-2019, 01:32 PM   #6
DieselDrax's Avatar
Nope, the purpose of the WDH isnít to raise the rear of the truck. Itís to distribute the weight to the front axle and some back to the trailer. Nothing to do with rear squat and Timbrens would not reduce how much weight the WDH needs to transfer. Itís the WDHís job to work hard.
Read your truckís owners manual to determine how much weight/height needs to be added back to the front axle with the WDH and make sure your WDH is properly adjusted when your trailer is loaded and ready to go. If youíre not sure how to adjust your WDH then the instructions are available online.
Thanks for letting us know why you were wanting to install them, you could have ended up with a very unsafe setup by trying to take weight off the WDH.
If youíre overweight then Timbrens or airbags will not help you. Thatís not their job.
2013 Shamrock 21SS
Old 04-12-2019, 01:34 PM   #7
I had Timbrens on a 2013 F-150 CC 4x4 that I pulled a 5th wheel with.
Big improvement towing and no noticeable ride difference unloaded.
I still have them (took off when I sold the truck) and would sell them cheap.
Days Camped: '16=46 '17=30 '18=51 '19=18
Old 04-12-2019, 09:15 PM   #8
florabama's Avatar
Timbrens fixed my squat. No maintenance, ever!
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
florabama is offline   Reply With Quote
Old 04-12-2019, 09:30 PM   #9
I put them on my 2014 1/2 ton Chevy and canít say enough good things about them or the customer service. I ended up with 5400 pound models. Perfect .. Jay.
Jay2504 is offline   Reply With Quote
Old 04-12-2019, 09:30 PM   #10
Same here 2014 f 150 squatted real bad fixed the problem less cranking as well. Had Sumo on Tundra and air cell on my last two at half the price of timbren or Sumo under payload buy 2k but they keep me level and I donít get flashed for high beaming
moose074 is offline   Reply With Quote
suspension
