Old 04-29-2014, 08:07 AM   #1
TIMBRENS
I have an 2008 f250 super cab-long bed with timbren installed and I pull a 41 foot 365saqb sierra with the rotoflex hitch on the RV. I can not believe how well this combination tows! hitting dips/bumps, chucking etc. Just thought id share incase anyone else can use this info. The only downside id it rides a LITTLE stiff with no load on but to me is well worth the trade off for something I NEVER have to think about again. On a 1-10 I would say the ride is now a 8 if it were a 10 before.
quick83 is online now   Reply With Quote
Old 04-29-2014, 08:14 AM   #2
Got home yesterday from our first long trip since installing mine. Noticeably better ride, porpoising was hardly notifiable. Very happy with this setup. I have not noticed any difference in ride without the 5ver hooked up, mine sit about 1 1/2" above the axle unloaded.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 04-29-2014, 08:23 AM   #3
mine are about 1 inch away from axle, but because I carry a lot of stuff in the bed they are riding about 1/2" away all the time so they make contact sooner when riding with no RV attached.
Old 04-29-2014, 08:45 AM   #4
I thought about putting the 1/2" spacer in to move it closer to the axle, glad I didn't from reading your OP.
Old 05-06-2014, 05:17 PM   #5
I had to call Timbren Customer Service because the recommended kit for my 2014 F-250 sat almost 2" above the axle unloaded. They recommended another kit which changed the distance to about 1" which has worked great.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 05-06-2014, 07:29 PM   #6
Mine on my Ram sit about 1"above the rear end also.Never touch with out the 5er on unless it's a very big bump.Makes the pulling much better.
DaveandSue is offline   Reply With Quote
Old 05-07-2014, 08:03 AM   #7
Boondocking Only
ddbck's Avatar
The Timbrens are FANTASTIC. I have had air bags on 2 different trucks that worked well also. I like the "Set it & forget it" Timbrens. Cheaper, less hassle, same result!!
2014 Shamrock/Roo 21SSL
Complete LED Lighting
Off Road Package
2010 F250 Lariat 6.8 V-10 w/Timbren SES
Custom Tunes by 5 Star Tuning
Boondocking Only
ddbck is offline   Reply With Quote
Old 05-07-2014, 01:38 PM   #8
I agree
Old 05-08-2014, 03:37 PM   #9
Thanks everyone. Without knowing it you have helped me solidify my decision. My TT is squatting my TV 2" even with WDH. I was debating between Bags and Timbrens and leaning toward the Timbrens due to the price, ease of installation and lack of maintenance but I wasn't sure if they would be as good as the bags. You all have answered alot of the questions I had. Can't wait to get mine now. Next time we hook the TT up (before Timbren install) I will be sure to snap a picture and then another one after the install.
2014 Salem 30QBSS
2010 GMC Sierra/E2/Primus IQ
swharrell is offline   Reply With Quote
Old 05-16-2014, 01:56 PM   #10
I think that if you are using a wdh, your are not suppose to use air bags or timbrens. They are good for a 5th t, not good for TT. According to an expert at E-trailer they"ll be fighting each other.
pibi is offline   Reply With Quote
