10-03-2012, 09:01 AM
#21
Which weight Timbrens did you all get. I got the 6000# model and it helps all around with sway and bouncing but it by no means stopped the thing from squatting. I may have picked up a half inch or so without any weight distribution hitch on. I still like the timbrens and would recommend them but they didn't seem to help as much as everyone else is stating. Maybe I should have went with the stiffer ones?
2013 Puma 30DBSS (Parked at Seasonal Site)
2001 Ford F-150
10-03-2012, 09:25 AM
#22
That's the big advantage to airbags, they put you in control of how much squatting, etc you have or don't have.
10-03-2012, 09:48 AM
#23
Unless you have experience with both, I can't see how a true comparison can be made. From what I have read here , both choices offer the same or similar result. One user may like the flexibility of adjusting the airbags and another may like the ease of install, price and maintenance free aspect of the Timbrens. It's all a matter of choice and preference. DUNNC, I'll give this match to you for your passion and great arguments for the airbag. Maybe if you try the Timbrens, you may have a different opinion. I cannot comment on airbags as I have never used them. Maybe next time around, I will opt for airbags. Cheers to all, whether you're riding on rubber or air.
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
10-03-2012, 10:03 AM
#24
Wasn't trying to win a match as you call it, just stating as I did previously that I don't want something controlling the ride height, etc. over which I have no option but taking what it delivers. The Timbrens may work perfect for some folks, I just prefer the adjustable features of airbags.
10-03-2012, 12:04 PM
#25
Why wouldn't adding a leaf in your springs do the same thing on the rear of your truck? I did that on a 1998 Chevy half ton and it was done with minimal amount of money and very little effort on my part doing it myself.
10-03-2012, 12:08 PM
#26
That would be fine if all vehicles had leaf springs, mine has coil springs as do others I'm sure.
10-03-2012, 12:12 PM
#27
When I use my truck for other purposes, I don't want the stiff, choppy ride. With the air bags, I just push a button and let the air down and if I want to carry a heavier load or tow the 5er, I push another button and add the amount of air I want.
10-03-2012, 09:19 PM
#28
Brigitte
Happy with my Timbrens (Thanks Rugged Brown) and I do not have to worry about them. Next truck and fifth wheel, I'll be using timbrens again!!!
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
10-03-2012, 09:22 PM
#29
............and on those campsites that are not level I can drop the rear of my truck 4" so I don't have to wait what seems like 10 minutes for my landing gear. Same with hooking back up. I can also raise the front of my camper 4" with my bags. All of this is done by a push of a button.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
10-03-2012, 09:26 PM
#30
X2
10-03-2012, 10:14 PM
#31
I had never heard of Timbrens when I bought the airbags but I am happy with what I have. I just have them each routed to the gap under my tailgate and air them independently. It's not a big deal if you know where they need to be loaded and empty. I think they were about $250 online and they install with simple tools in under an hour & I am not a mechanic.
2015 Sierra 357TRIP
2012 Ram 2500 CCSB 6.7CTD
10-04-2012, 01:18 PM
#32
I betcha your airbags don't produce beer on tap like my Timbrens.
10-04-2012, 01:30 PM
#33
I have air bags with a Viair 10007 onboard air system. I always thought that airbags were not needed if you had a dually. Wrong! lots fo people have them on everything from half tons to 450 series trucks. I was pleasantly surprised when I added them to my dually. Even though my pin weight is around 3000 pounds, the truck would sometimes porpoise really bad on the interstates. Now at just the touch of a button, I can stop that! Run them at about 12psi when empty(actually rides better now) and then about 30-35 when loaded. Plus, I put an air chuck under the side of my truck so I have air available for tires, floats or what have you. Never had Timbrens, just bags. Won't tow heavy again without them.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
10-04-2012, 02:08 PM
#34
No, but they can sure pressurize the keg.
