Old 08-10-2012, 06:57 AM   #1
Camper Less Camping
Cajun Po-Boy's Avatar
Timbrens vs Air Bags
I like the "install and forget about them" concept behind the Timbrens but do you get the same degree of leveling the rear of the truck as an air bag system?
I understand the convenience of adjusting air bags for various load weights to the truck so you can get perfect level as necessary but is it much different than the Timbrens?
Have an '05 Chevy 2500hd 6.6 and the bed cargo capacity is over 3K lbs and our new fifth wheel pin weight will come in around 2-2250 lbs when loaded, thinking I may not even have much of a rear sag issue.
Any thoughts will be helpful
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-10-2012, 07:30 AM   #2
Bags come into play at (Your) discretion,Timbers come on at load touch. Youroo!!
youroo is online now   Reply With Quote
Old 08-10-2012, 09:20 AM   #3
I would go with the air bags and an onboard compressor. That way YOU control the amount of height. With the Timbrens, you have to accept whatever you get.
Old 08-11-2012, 04:07 PM   #4
I installed Timbrens because I only needed a little help. They work great and do not affect the unloaded ride since they only touch when the bed drops more than one inch. I read in Turbo Diesel Register that they are equal to about 10 lbs Firestone Air. Also, they cost less than $200.00.
jdecanter is offline   Reply With Quote
Old 08-14-2012, 07:55 AM   #5
For another $100 you could have airbags, and you can install them yourself in the driveway in about 4 hours. See this link:
http://powerstrokearmy.com/forums/sh...ad.php?t=21571
Kris
2012 Sandpiper 365SAQ
2008 F250 Lariat CCSB, Deleted and Tuned
mortal798 is offline   Reply With Quote
Old 08-14-2012, 08:03 AM   #6
TURBS's Avatar
Big big fan of air bags.
Got them on my 05 Silverado 2500 hd
And my 99 suburban.
Old 08-14-2012, 09:24 AM   #7
I have not had Airbags but have Timbrens. I must say that I am less than impressed. It did help keep everything tight in the back end and sway is much better but for leveling, it is doing almost nothing. If I had to do it again, I would do airbags.
2013 Puma 30DBSS (Parked at Seasonal Site)
2001 Ford F-150
travyp is offline   Reply With Quote
Old 08-14-2012, 10:44 AM   #8
J_KHawthorne's Avatar
Love the air bags... I routed the lines so the nipples are either side of my rear license plate... easy to fill and adjust. When not towing, I drop the pressure to ~ 10psi which pretty well returns the truck to factory suspension.
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 08-14-2012, 10:52 AM   #9
Why not add a 'T' and fill them both at one time?
Old 08-14-2012, 01:40 PM   #10
Fire Instructor's Avatar
My Timbren installation did the trick for me. Easy to install, zero mantenance, no propensity for failure. (Especially a failure on-the-road, when you can do little to properly repair it!)
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
air bags
