Old 07-06-2015, 10:22 PM   #1
roadmaven's Avatar
Time for a new (used) TV: GM vs Toyota
Just a bit of background:
This spring we upgraded our trailer from a 16' Scotty to a 29' Shasta. My tow vehicle is a 2003 Toyota Sequoia 4.7L. Never had a towing issue with the Scotty paired with the Sequoia. However, the Shasta and Sequoia don't seem to get along too well! In a separate thread, I inquired as to getting a handle on the squirliness the Sequoia experiences when getting passed by a semi, box truck, or a plastic bag. After many suggestions that I've tried, I've come to the conclusion that the Sequoia's wheel base is just too short (118.2") for the 29' Shasta.
We got pre-approval from our credit union for a loan today and we're keeping it at $17K to borrow for an upgraded tow vehicle. I'm going back to a pick-up, and it'll be a crew cab, since we have two grandsons still in car seats that will camp with us from time to time. Per our credit union, they'll only go back as far as a 2005 and as high as 125K miles. I love my Sequoia dearly, but if I'm spending this kind of $$, one of the trucks I"m going to look at is a 2007+ Tundra Crewmax. With the upgraded 5.7L and tow capacity, I'd much rather overkill it than be marginal with a pre-2007 Tundra. We camp rather light, and "if" we have any water onboard the Shasta, as well as other "stuff", we'd be looking at a trailer weight in the 5200lbs range TOPS. I've recently weighed the tongue and it checks in at about 640lbs.
My other choice would be a Silverado/Sierra of the same 2007+ era, crewcab with a 5.3L. Tow capacities of the GM vs Tundra are around 7500 vs 10,000 from what I can tell, and payload is in the 1600 lbs range for either.
So, based on these TWO choices only, any opinions on what's my best bet? Is one a no brainer compared to the other? Opinions always appreciated!
Pat B.
Speedway, IN
2016 Shasta Oasis 18BH
roadmaven is offline   Reply With Quote
Old 07-06-2015, 10:31 PM   #2
bikendan's Avatar
Which ever has the most payload.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-07-2015, 06:25 PM   #3
Im happy with my toyota! I think the crew max has alittle less carry on weight than my DBL cab. Do some research.............
ID:	82288   Click image for larger version
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 07-07-2015, 09:03 PM   #4
RPAspey's Avatar
I like my 07' Tundy and 31' 7.5k+ TT. It towed great stock, but even better with a few mods. Like rear sway bars ($125 or so) and high performance front rotors and pads. otherwise its a beast. I have around 95k miles lots of it towing without problems.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-07-2015, 10:00 PM   #5
HONDAMAN174's Avatar
Cargo cap for crewmax is around 1300. But if your tongue weight is let's say 700, you should be just fine unless the grandsons are built like wwf wrestlers!
I have done some upgrades to Clifford- Trd exhaust, afe intake and sumo springs to help with my high tongue weight. I am also using Anderson hitch and very happy with it now I have finally got it dialed in to my setup.
Just glad to get away
Old 07-07-2015, 10:16 PM   #6
My 2 cents:
If you go with a Silverado, make VERY sure you know how it's optioned. My 2009 Silverado owners manual list 99 (that's NINETY-NINE!!!!) permutations of engine, cab, rear axle, tow package, 2WD/4WD, etc. The tow capacity ranges from about 4000 lbs up to 11,000 lbs. (Mine's good to 7500 lbs, for example.) So you HAVE to know what the specific vehicle you're looking at is rated to tow. (This is another reason that any salesman that tells you "Oh, a 1/2 ton can pull this," is full of BS! All 1/2 tons are NOT created equal.) The other brands have similar issues.
Also, I highly suspect that you're going to end up packing more stuff in the Shasta than you did in the Scotty. So your weight may end up being a bit more than you're estimating.
2011 Traverse LT, 3.6L, FWD
Old 07-08-2015, 12:11 AM   #7
I am on my 3rd tundra now for a daily driver, I put 250K on the 2007 as well as the 2011. My 2015 has 29K on it now. (I drive about 85K/year for work)
Tundras are very hard to beat for reliability. I NEVER got that may miles out of GM or Ford trucks when I had those. The 2011 was without a doubt the BEST vehicle I have ever had and I had all of them.
My only complaints for towing would be the rear springs are VERY soft and the P rated tires instead of LT tires. The bumpers are very thin and if you bump them with the tongue of the trailer you WILL dent them.
With that being said I tow my fifth wheel with a Dodge Ram 2500 with a Cummins diesel because it is too heavy for anyone's half ton truck. The dodge typically only sees ~5k/year
Jeff in NC is offline   Reply With Quote
Old 07-08-2015, 12:37 AM   #8
roadmaven's Avatar
Jeff - Perfect segway! On another forum where I posted this, I had a responder contact me offline regarding an '06 Ram 2500 with a Cummins diesel and 56k miles they're selling for just under $23k. I know squat about diesel engines, but was intrigued with his ad. I'd never have to worry about any towing concerns for sure! Anything you can share in regards to yours for a novice like me?
Pat B.
Speedway, IN
Old 07-08-2015, 10:58 AM   #9
I have an 07 2500 Diesel that I towed my 37ft Heartland Big Horn, 14,100 on the scales, no issues. Yea Yea, way over however the truck didn't care, pulled at around 63 to 65 MPH on average with cruise set and AC on. Not saying or recommending anyone tow that heavy, just pointing out the Cummins diesel 5.9 (same as 06 above) knows no bounds. Weak points, if not properly maintained are transmission, fuel systems.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 07-08-2015, 11:11 AM   #10
Either are fine for your setup. If you went with the GM, I'd try to do the newer body style 07.5+ and make sure it has the factory tow package. If you can swing it, in 2009+ GM put in the 6 speed auto in the 1500s so more power, better ratios, and milage.
Good luck.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
toyota
