05-10-2016, 11:38 AM
#21
Originally Posted by Iwannacamp
25 years in the auto parts business taught me much about noisy brakes and dirty rotors.
Customers/users are hardly ever happy. I will give my opinions(couple anyway). Inexpensive.. but last. Clean and quiet. Friendly to the environment and the rotors.
Brake pad bonding was done on purpose(glued to caliper). Noise starts at the rotor surface and is transmitted and sometimes amplified through the hardware.
Smooth rotors(but not glassy), clean lubricated hardware(caliper has to move). Quality product. Rotos are lighter than they used to be, but yet most not ventilated and are doing sometimes 80% of the work. Just as important as anything make sure to wash the rotors before and after installing. I could go on.
here you go...
The Perfect Brake Job
Took a look at the link.... IMO, the most important step to alleviating squealing brakes would be #29 (lubricate pads at all metal-to-metal contact points to include shim on backing plate)
The shim lubrication is often overlooked and has made a difference when doing it myself.....
J.
05-10-2016, 11:40 AM
#22
talked to a friend who does brake work her said on the 3/4 ton and up trucks use OEM or go to NAPA for brakes as most auto shops sell what they can buy cheep and make there money off and they don't hold up near as well
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
05-10-2016, 04:12 PM
#23
No noise here
I always use OEM pads on my rigs. That doesn't mean I go back to the dealer to get then though. Let your fingers do the walking and find your best price on-line. I have never had a squeak from using the factory pads, they cost more but I hate squealing brakes.
05-10-2016, 04:19 PM
#24
Always Learning
If you buy the brake pads online, who does the install?
05-10-2016, 04:26 PM
#25
With disc breaks changing out pads and rotors is for the most part very easy . just did mine on my 2500hd chevy . new rotors front with semi-cermic pads lifetime warranty and new pads on the rear . total time 1.5 hrs and that's me taking extra time to lube the front end and clean things up very well . if you've never done it then take it in most lifetime warranty break jobs will be less then $250
05-10-2016, 06:30 PM
#26
Usually you do .......... unless you have a mechanic like I do that will do it for $20. A few will do it most will not do to liabilities.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
05-10-2016, 07:15 PM
#27
Wagner Ceramic and hose off the rotors on occasion
05-10-2016, 09:09 PM
#28
New to FR. Old to TT
I have been using ceramic pads on all my vehicles for atleast 10 years and have loved the great gripping and quite braking. a BIG plus is no break dust messing with my wheels.
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
05-10-2016, 09:27 PM
#29
I am about to replace all 4 corners on my Tundra. I will use ceramic pads with slotted and drilled rotors. I tow in mountains and the fronts have a problem with heat build up and shake like a dog when they get hot.
That said, if you have ANY mechanical aptitude, replacing rotors and/or pads is as easy as it gets and you'll save more than enough for premium parts.
05-10-2016, 09:47 PM
#30
Brakes are not difficult, run the rotors down to local parts store they can turn them, or replace them. Pad's, OE, clean and lube all slide pin's, contact point's, the best pad's actually have an adhesive on them so when the caliper is extended from being used they actually glue themselves to the caliper/piston, this pulls the pads off the rotor when the brakes are released. Some also have fingers on the slides to push the pads off the rotors also. No drag all around. As far as noise, it comes down to rotor finish, good luck.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
05-10-2016, 10:35 PM
#31
Campground host Mo. State
All disc brake pads have a metal tab attached ,when the pads need replacing the tabs touch the rotors making a squeal indicating the need for replacing before they are metal to metal.
Frank & Kathy & Daisy 2.0 Yorkie (Pack leader)
2008 Ram 6.7 Diesel, 4.10 diff., EGR valve delete, MBRP straight exhaust, Mini Max race tuner, K&N
2016 Crusader 321 RES Ham call W0FCG
Days camped in 2015- 111 in 2016-75 in2017-61
05-11-2016, 05:17 AM
#32
X2
I was taught the same thing. But if two shops didn't see this, I'd check runout on rotors, turn if needed, and replace with stock pads.
Good luck,
Dave
05-11-2016, 06:39 AM
#33
Not all pads have the tab.
That's why brake inspections are needed.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
05-11-2016, 07:40 AM
#34
I do 90% of my own work and I was looking for 1) A quiet pad\rotor combination and 2) A near dust free rim. What I decided on 3 years ago was a Raybestos heavy duty set of front slotted rotors and NAPA ceramic heavy duty brake pads. The outcome was an extremely quiet braking application in all weather and speeds with very little brake dust. I bought my rotors and pads thru Rock Auto parts online.(they had a wholesale closeout price on the pads). A few folks have commented on how ceramic pads weren't the best when towing heavy, but I've had NO diminish in stopping power at any speed. Doug, buy online, and have a good local Independent garage do your install. If we lived closer I'd turn you into a shade tree mechanic over a few beers...
05-11-2016, 02:53 PM
#35
As a professional automotive technician for over 35 years. If you machine the rotors due to lateral run out or thickness parlisium. Correct finish and washing machine surface with soap and water with a stiff Bristol brush. Never use anti seize lube on anything for brakes. Not compatible with rubber, use a high temperature brake lubricant and replace shim hardware. O.E brake material is best. Use common sense when braking as pads need time seat. Do not use heavy braking when getting pads to seat. Use moderate braking, do not use light braking as pads glaze and will cause noise. You should also flush the brake fluid system with new fluid. Brake fluid absorption of water is normal and even with a sealed system. This is why brake fluid turns darker and breaks down also with heat. Good luck
05-11-2016, 03:16 PM
#36
2016 Sabre 36QBOK
Thanks Kenny. Been in the automotive after market 40+ years (15 of the those managing a brake supply warehouse) not all pads have wear sensors.
05-11-2016, 03:17 PM
#37
Do vehicle manufactures make their own brake pads/shoes?
06-04-2016, 08:38 AM
#38
Always Learning
06-04-2016, 11:22 AM
#39
Those shock boxes look familiar.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
06-04-2016, 11:23 AM
#40
Always Learning
And here's my view- working on my cousin's computer! I was nothing more than moral support out in the garage anyway.
