Old 07-13-2015, 04:46 AM   #1
Tire pressure guages
Hello everyone. I'm fairly new to this great forum, but have been lurking a while. I have a question that I haven't seen addressed concerning tire pressure guages. I have several manual guages. (Chrome tube with a sliding scale inside it). Have used these type guages forever. Just found that my guages all read different, and my "go to guage" reading low by 20+ pounds.
This has become more significant because I've experienced several sidewall blowouts the last few months. (Whole 'nuther story)
So, after this discovery, I bought a digital pressure guage from Walmart, and had to go back and put air back in all the tires on truck and fifth wheel before our trip today. (Picking up our new Silverback 29RE)
That's the back story.
Question is; what kind of tire pressure guage does everyone use, and how do you know it's accurate?
Thanks for any and all replies. Seems to be a great forum.
David
Davidg is offline   Reply With Quote
Old 07-13-2015, 05:35 AM   #2
SYE
SYE's Avatar
I use one like this that I put a tire check on. I calibrate it by using a Fluke Air pressure calibrator. I did the initial cal about 14 years ago, i just recheck it every spring and it has been good
McMaster-Carr
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 07-13-2015, 06:07 AM   #3
DavidG - really good question and one I've been meaning to ask.
SYE - your link goes to a whole page of gauges - I'm not smart enough to know which one you are using. Does it have a model number?
Looking forward to other replies as I am sure I need to upgrade from the $2 variety as well.
Brian
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 07-13-2015, 06:10 AM   #4
SYE
SYE's Avatar
Brian
4089K64
Scott & Vicki
2021 4 reserved
Old 07-13-2015, 06:12 AM   #5
SYE
SYE's Avatar
then I put one of these on the 1/4 inch inlet
McMaster-Carr
6146A23
Scott & Vicki
2021 4 reserved
Old 07-13-2015, 06:18 AM   #6
RSchleder's Avatar
I also use the metal gauge with the extending portion that tells me the tire pressure. I agree with you on the variance on this type of tool. I probably had 6-8 of these gauges that I'd picked up over the years at car shows, swap meets, etc. I threw them all away. My current gauge came from NAPA, is all heavy duty metal, cost about $40, is about 3-4 times larger than the "give aways" and has proven to be extremely accurate. I know this because it always agrees with the heavy duty gauge built into my inflation tool on my large compressor. I have never used a high quality digital gauge, however, the cheap ones have proven very in-accurate in my experience.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-13-2015, 06:35 AM   #7
Thanks SYE!
ProPride Hitch
Old 07-13-2015, 06:36 AM   #8
SYE
SYE's Avatar
Agreed, the cheap ones are garbage, I was actually looking at them at the Pilot/Flyin J over the weekend, and yes they were expensive.
Scott & Vicki
2021 4 reserved
Old 07-13-2015, 06:41 AM   #9
I race cars as a hobby so I'm aware of how gauges can be crap.... I use a certified racing gauge for most of my equipment. They can run $45 and up but they last for a long time and the ones I use have a glow in the dark face so you can easily read it in low light. Longacre is one of the brands I use. These are the entry level gauges and they are still are accurate +\- 1.5lbs at 100lbs. Not bad for under $50. They have units in the $300-400 range if you need insane accurate. Lol.
http://www.longacreracing.com/produc...ith+Foot+Valve
Or if you like digital
http://www.longacreracing.com/produc...uge++0-100+psi
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 07-13-2015, 06:42 AM   #10
mcnabbwr's Avatar
I use a Milton gauge to verify what my TST pressure monitoring system is showing. This analog gauge has been very accurate. I also use a cheaper digital gauge I picked up at a local auto parts store for quick checks, and it's within a pound of my good one.
Amazon.com: Milton S986 Service Gauge - Straight Foot Dual Head Chuck: Automotive
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 07-13-2015, 08:40 AM   #11
Jim34RL's Avatar
I purchased a digital air pressure gage that will read to within +/- 2 psi from NAPA for under $35.00. I use this to air the camper tires and TV when towing. I have checked this gage against my three air compressors and they all read within 2 psi of each other.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 07-13-2015, 08:03 PM   #12
Mr Mcnabbwr, my "go to" guage has been the Milton S986....until I found it reading 15-20 PSIg low. I would hate to think that my old faithful Milton is the reason for my chinabomb tires going off.....especially when I've always been diligent about tire pressure. But if I've had 60 psi when I thought i had 80.....well....that could be a problem.
Thanks for all the ideas...including a few options I hadn't thought of
Old 07-29-2015, 10:35 AM   #13
I stopped by the local NAPA store the other day. Took a close look at their digital gauge. It was marked at $25, but when I went to pay for it, turned out it was on sale for $15. I wish it had a "hold" feature on it that would hold the last reading. You have to be looking at it straight on when taking a reading, otherwise you just can't read the numbers.
Certainly not a deal breaker,....it is just not as convenient as a gauge that holds the reading.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Old 07-30-2015, 12:44 PM   #14
schrederman's Avatar
I have one of these I got a couple of months ago. I have access to a calibrated source and this digital gauge is accurate to .1 psi, so far. I had to pay full price for mine....... I agree that it would be nice to be able to hold the reading. It can be hard for old eyes to see in the sunlight...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
pressure, tire
