04-26-2014, 05:01 PM
#41
Commercial Member
Originally Posted by lbrjet
I have read that you shouldn't use a lower pressure than 70% of the max rated pressure in any tire. That is 56lbs so I guess that is not too far off if Michelin says not lower than 60.
If you want to do the least damage possible on your multi axle trailer there is solid engineering data that supports running the tire max 100% of the time. (We only talk cold set pressure here not operating pressure)
The damage is called "Inter-Ply Shear" and I have done a post on my blog just on that topic if you are interested in the technology behind my recommendation.
Where did you read the 70% of max claim? You can PM me if you wish.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
04-26-2014, 06:30 PM
#42
I don't recall where I read it.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
04-27-2014, 08:08 PM
#43
Commercial Member
Well whoever told you to run less than the tire sidewall max on your multi-axle trailer obviously does not understand vehicle dynamics and the effects of cornering on the belt package inter-ply shear.
04-28-2014, 10:21 AM
#44
This thread was about truck tires.
05-03-2014, 03:15 PM
#45
Commercial Member
My bad. I was looking at the trailer avatar.
05-06-2014, 12:18 PM
#46
Setting up for the summer, I went with 65 on the rear and 55 in the front on my Michelin LTX M/S2. Discount Tire said to do 80 and I said no. Any arguments to how I had mine setup?
2013 Palomino SolAire 317BHSK w/Eclipse package using a ProPride 3P Hitch
2013 Ford F-150 Ruby Red SuperCrew 4x4 EcoBoost w/Max Tow, e-lock, Michelin LTX M/S2 tires, & Air Lift 5000 Ultimate w/Load Lifter
Campers: Me, DW, DD, DS
Nights camped: 2015 (4) as of 5/25 2014 (44) 2013 (26)
ProPride Review
05-06-2014, 12:25 PM
#47
Sure not with me, I do very similar. 55 front 60 rear when towing, 35 front 30 rear not towing.
05-06-2014, 12:49 PM
#48
Currently running 55 all around on my Michelin LTX AT/2 tires. I had 1.5 inches of squat when hitched with these tire/pressure compared to 4 inches with Stock Perrelli P Series. I went with the more aggressive tread for the snow we get here, never stuck since purchase.
B and B
05-06-2014, 01:07 PM
#49
Commercial Member
Not knowing your actual F & R axle loads when hooked up and when not hooked up it's impossible to give an informed answer other than to point to your vehicle placard. But if you have changed tire size then you can only get a correct answer based on your actual axle loads fo r the TV.
Someone advising you what they use for inflation is like telling you the pants size you should buy because they wear size 40x29.
05-06-2014, 01:14 PM
#50
Can I supply the door sticker and tongue weight or would this be something where I go to a scale and find the actual axle weights?
ProPride Review
05-06-2014, 01:19 PM
#51
Commercial Member
Info on the Placard or "door sticker" is the MAx axle load. No way of knowing if you are over or under the Max without actual scale weight. I suggest truck stop or local gravel or grainery.
Check yellow pages for "Truck scale" or google "CAT scale or "Truck Scale"
05-06-2014, 01:21 PM
#52
Thx
ProPride Review
05-06-2014, 09:53 PM
#53
Do manufacturers publish inflation guidelines for each tire they manufacture, perhaps with a table providing a range of pressure over a range of loads?
Chris Cowles
Gainesville, FL
Former pop-up owner
Hybrid owner wannabe
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
05-07-2014, 03:28 PM
#54
Commercial Member
Chris Cowles
Gainesville, FL
Former pop-up owner
Yes the reputable ones do. BUT If you are pulling a multi axle trailer you should always set the cold inflation to the inflation on the tires.
If you have a motorhome you can adjust the inflation to the psi needed to carry your measured tire load on the heaviest tire on each axle +10% and all tires on an axle should have the same inflation.
Read my blog for more facts on tires.
