Originally Posted by Hersbird
I doubt there is an E load tire made that will provide for the factory ratings at only 32 psi some door stickers call for.
I know a 2000s Chevy Z71 only calls for 30 psi front and rear, that is just too low for an E rated tire, I don't even think that low of a PSI is even on the load tables.
Okay, I’ll do it like this. The P275/70R17 provides 2260# of load capacity at the placard recommendation of 32 PSI. That is the minimum load capacity for replacement tires of any design. The LT275/70R17 will provide 2269# of load capacity at 42 PSI, anything above that is optional. (The vehicle manufacturer accounted for the 10% reduction in load capacity for the “P” tires when they installed them).
To verify my numbers use the chart provided in post #41.
