Old 07-17-2014, 09:31 AM   #1
dhatfield6's Avatar
Send a message via Skype™ to dhatfield6
Tire rotation
How many folks rotate the tires on their 5ver. I have a XLR 380 AMP with 3 axles, which way should they be rotated?
Doug & Kim
2013 Forest River Thunderbolt XLR 380 AMP, 2013 Ford SD F-450 DRW 4WD CC 172" King Ranch
2012 H-D FLHTK Electra Glide Ultra Limited, 2004 H-D FXSTDSE2 Screamin Eagle Deuce
[FONT=Arial]Trips in 2013-(4) Nights Camped-(56) Trips in 2014-(5), Nights Camped-(60)
Trips in 2015-(4) Nights Camped-(44) Trips in 2016-(2) Nights Camped-(17)
dhatfield6 is offline   Reply With Quote
Old 07-17-2014, 09:35 AM   #2
TURBS's Avatar
Been discussed here many times.
Personally id swap them side to side.
Then move each tire one position back and the back one to the front.
Jmo.
Old 07-17-2014, 12:07 PM   #3
Don't know if it's an old wife's tale, but I've been told to not reverse the direction of rotation on radial tires, so, IF that is true, you would just move the ones on each side to a different position on the same side.
Old 07-17-2014, 12:49 PM   #4
f5moab's Avatar
http://www.tirerack.com/tires/tirete....jsp?techid=43
f5moab is offline   Reply With Quote
Old 07-17-2014, 12:50 PM   #5
TURBS's Avatar
Fronts straight back and criss cross the rears forward that would be normal.
Or is it rears straight forward and criss cross the fronts back?
Old 07-17-2014, 01:10 PM   #6
Originally Posted by f5moab View Post
That applies to cars and trucks. I've never rotated tires on a trailer as they are not like the steering tires and drive tires on cars and trucks. The tires on trailers age out long before they wear out. To me, it isn't worth the effort.
Old 07-17-2014, 02:50 PM   #7
DaveSchwartz's Avatar
I never rotated tires on my previous TT and never had uneven or unusual wear and lasted way longer (9 years) than they had any right to. Of course, always inflated to max for LRC (50psi) and always covered when in its home location.
I looked at the Goodyear site and their only recommendation is to adhere to the trailer manufacturer's recommendation and the Forest River manual doesn't have one. Therefore I have no plans to rotate the tires.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 07-17-2014, 04:09 PM   #8
TURBS's Avatar
It'd be a great question to ask the lippert guy at the rally!
Old 07-17-2014, 04:28 PM   #9
OutlawAdventurer's Avatar
I never rotated tires on any of my trailers, either....one thing I do is raise them high enough to rotate tire about twice a year when I pump grease into bearings. other wise only maintenance I do is, pump a little grease before each long trip and check tire pressures....
OutlawAdventurer is offline   Reply With Quote
Old 07-17-2014, 05:30 PM   #10
f5moab's Avatar
Then say so....you stated, "Don't know if it's an old wife's tale, but I've been told to not reverse the direction of rotation on radial tires," never saying "trailer only."
Old 07-17-2014, 06:25 PM   #11
DDC
DDC's Avatar
I'd like to see this one backed up with facts please.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-18-2014, 02:20 PM   #12
There was a time in the early years of radials that cross rotation was not used. At that time there was a belief that the steel belts would get oriented to the direction they were turning and reversing that could loosen the belts or cause other stresses. As time went by this was shown not to be the case and manufacturers went back to recommending cross rotation.
As far as car, trucks or trailers I don't see any difference in the rotation criteria. A tire is a tire when it comes to that. Whether rotating trailers tires is needed is a different issue.
keith_h is offline   Reply With Quote
Old 07-18-2014, 02:42 PM   #13
Happy Keystone Owner
dbarr's Avatar
Tire rotation
Not at my house!
I don't rotate and they wear evenly.
Sent from space
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
dbarr is offline   Reply With Quote
tire
