Old 06-25-2014, 09:17 PM   #1
Tire Wear
2014 29BH Grey Wolf has really bad tire wear on inside of tires. I just boight this trailer 2 months ago, and have only put a couple hundred miles on them. Tire pressure is fine. Why is it doing this? Its really bad almost bald.
Sent from my SAMSUNG-SGH-I717 using Forest River Forums mobile app
jason80 is offline   Reply With Quote
Old 06-25-2014, 09:21 PM   #2
Crusadernoob's Avatar
Bent spindle and/or axle. Not overloaded are you?
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 06-25-2014, 09:33 PM   #3
DDC
DDC's Avatar
Back to the dealer with it, let them tell you whats wrong.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-25-2014, 10:31 PM   #4
No its not overloaded at all, I take the minimum and havent even filled the fresh water tank. I put mostly everything in back of my truck. Good thing for warranty!
Old 06-26-2014, 05:59 AM   #5
DaveSchwartz's Avatar
Then your axles are probably on upside down or way undersized. Trailer axles are supposed to have an arch upwards in the middle so that they flatten out under load and the camber goes close to zero. Sounds like your arch may be absent or down in the middle when off the ground and gets bigger under load so your camber increases, moving the contact patch to the inner shoulder of the tires.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 06-26-2014, 06:18 AM   #6
MilCop4523's Avatar
A buddy of mine had similar issue with a different FR product. His Axles were get this .... one upside down and one was bowed so badly it couldnt be fixed. they replaced both axles. My tires wore almost bald on teh in and outsides because they only put 40 lbs pressure in each tire and after getting it home to Canada we noticed the error.
go get the unit checked for alignment and other specs.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 06-26-2014, 06:23 AM   #7
I hope they replace all four tires. Im sure its the axles. This is not a way to start off enjoying a new family toy. Thanks guys for your replys.
Old 06-26-2014, 07:40 AM   #8
At least upside-down errors can't occur with torsion axles (or would be immediately obvious) because the torsion arm offset would have the wheels not lining up with the cutouts.
Old 06-27-2014, 06:12 AM   #9
Incheon, S. Korea
BigBaron's Avatar
Here we go again...
Inside edges of all tires? Camber.
Crawl under and check what axles you have.
I'll bet that GVWR - hitch weight equals the combined capacity of the axles...
e.g. 7,753 - 753 = 7000 lbs divided by two gives us two (2) 3,500 axles.
Specs
Shipping Weight 5,969 lbs
Carrying Capacity 1,746 lbs
Hitch 753 lbs
GVWR 7,753 lbs
Good luck!
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 06-27-2014, 06:39 AM   #10
my tires did this and after a small battle with lippert. they agreed to replace the springs and the axles. turns out they replaced my 3500 lb axles with 5200 lb axles. then they replaced the bias tires with radials. they wont admit it but they got a bunch of campers running around out there with shall we say borderline axles under them. I had to almost prove to them was there problem. salem 27rkss. 2014 model
rr retired is offline   Reply With Quote
tire
