Old 02-23-2019, 01:06 AM   #1
Tires
Wanting to upgrade from an E rated tire to either a F or G for nitro xlr triple axle . What are the best tires u guys are having luck with?
k8271 is offline   Reply With Quote
Old 02-23-2019, 09:04 AM   #2
I canít provide any advice on the subject but want to say thank you . I read your post and wondered. Why one would want to go to such a stiff tire thinking that tires that stiff would beat the trl and contents to heck. I didnít want to tp post a rude or confrontational post. So I did some research learned a ton I didnít know and probably never would have if you hadnít made the post
moose074 is offline   Reply With Quote
Old 02-23-2019, 09:13 AM   #3
I like my Goodyear G614 on my Cedar Creek. Iíll probably go with the tires again when and if I wear them out or age them out
spock123 is offline   Reply With Quote
Old 02-23-2019, 09:21 AM   #4
Many seem to be going with the G rated Sailun S637 tire if youíre running 16Ē rims that are capable of handling 110psi.
I put them on my new trailer before it left the lot - http://www.gosailun.com/MRT/Tire/S637T.
jtaylor1920 is offline   Reply With Quote
Old 02-23-2019, 10:29 AM   #5
I just finished doing a bunch of research on the subject for my tires my size is 235/80R16.
My rims are capable of 110 psi and my trailer Came with load range E. I wish I would have changed to Salunís before my trailer left the lot. Three blowouts later over 10,000 miles Iíve switched to Goodyear endurance.
The main reason I made the change was availability of load range G tires in my tire size ó they seem to be scarce. I didnít want to be caught on the road having to replace a load range G tire and not being able to find one. Additionally I had just purchased two Goodyear endurance tires on the road already so they were brand new and Itís not recommended to mix and match load range.
That said, the Sailun tires are available on Amazon prime
When I have to replace the set, it will be with sailuns. Their product quality reputation and customer service is unmatched.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 02-23-2019, 10:30 AM   #6
Did these tires come stock on your trailer?
Old 02-23-2019, 10:53 AM   #7
Thanks for all the comments and the lack of negative comments ( moose ) . Lol . I have been looking at the sailuns . With that said , this may be a dumb question but how do i tell if my wheel is rated for 110psi ?
Old 02-23-2019, 11:23 AM   #8
Airdale's Avatar
If you suspect load capacity might have been a factor in your tire failures you may have compounded it with the Endurance tires. Many of the OEM tires in size ST235/80R16 LRE have a maximum load capacity of 3520#. The Endurance in that size and load range provides 3420# of load capacity.
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 02-23-2019, 11:34 AM   #9
Yes
Old 02-23-2019, 12:57 PM   #10
WFD
Normally stamped inside the rim, so you will need to remove the tire to see it.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
tire, tires
