Old 07-19-2012, 08:55 PM   #1
Tires
The truck I bought came stock with 20" tires (michelin 275/65/20E) and it tows great. I am curious if 20" is better than 18" or does it really matter? Gas mileage worse or Better?
pwrstroke2012 is offline   Reply With Quote
Old 07-19-2012, 09:32 PM   #2
acadianbob's Avatar
Not a big deal. Some people prefer the look of 20's. Some people prefer the higher sidewall height of the 18's to provide extra cushion and shock protection under heavy loads. Depends on how you use your vehicle IMO.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 07-20-2012, 12:07 AM   #3
Rsgtivr6's Avatar
It can be a little bit of a game changer. If you keep the same aspect ratio, the 18" wheels will have a smaller diameter, therefore a smaller circumference. This will come out in the end to be less distance traveled per revolution with the smaller tire. You may lose some mileage (probably not too noticeable) and might need to get your speedo calibrated, but it might give better low end pull for towing. With the decreased rolling weight of the smaller rims, though, it might all come out in the wash with mileage since each pound of rotating weight you lose is equivalent to losing 10 lbs of static weight in terms of performance and mileage.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 07-20-2012, 06:50 AM   #4
Wanna Be Camper
SaskCampers's Avatar
Assuming you were to go to the 275/70 18 that Ford uses and you had 3.73's your axle ratio would change to abt an effective 3.83 as there is abt .9 inch difference in the diameter of the 2. Resulting in a bit more pulling power and as to mileage who knows maybe a bit better as I know going from LT265/70 17's to LT285/70 17's I took a mileage hit as they are bigger and wider. Although in your case they would both be the same width.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-20-2012, 07:00 AM   #5
Don't think the width would have any effect on mileage as much as the diameter.
Old 07-20-2012, 09:01 PM   #6
Brigitte
boubou's Avatar
just got these same tires for the Ram to replace the P275/60R20
I debated the same exact point and was result was, stay with the 20's, less bouncy than the 17, less sidewall.
Love these tires by the way! big improvement. The Wranglers HP felt squishy while towing.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 07-20-2012, 09:23 PM   #7
Location: No longer own a Forest River product, but enjoy the info on this site
The weight of the tire will.... all things equal, a heavier tire will provide less MPG.
Check the specs on the tire.
teamgl is offline   Reply With Quote
Old 07-20-2012, 09:30 PM   #8
Think one would be hard pressed to document the fuel mileage difference strictly dependant on weight of the tire, assuming all other dimensions were the same.
Old 07-20-2012, 09:45 PM   #9
( all things equal ) A heavy tire = lower MPG. simple physics my boy.
Old 07-20-2012, 10:22 PM   #10
Dave_Monica's Avatar
Maybe if we're calculating fuel mileage to the second decimal place. Don't think I'll be putting tire weight at the top my list of tire requirements! We're talking heavy LT tires aren't we?
Dave
