Old 02-16-2015, 09:44 PM   #1
GuppyWN's Avatar
Tires?
Have a Tundra with airbags and a WD hitch and just upgraded to a Wildcat Maxx 28RKX that weighs 7300lbs. What tires should I put on the tow vehicle? Looking at Michelin LT tires from Costco but not sure if they are D or E rated but it appears they are D rated. Is this enough tire for this setup?
Thanks in advance.
GuppyWN is offline   Reply With Quote
Old 02-16-2015, 09:47 PM   #2
Flagstaffer06's Avatar
My opinion only, but if you are buying tires and you are towing that type of weight with any half ton truck. I'd certainly make sure you are going with E rated tires.
E will give you the best rating with a stiffer sidewall to help while towing.
Hope that helps somewhat, I'm sure Costco can give you the information you are looking for.
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 02-16-2015, 11:53 PM   #3
HONDAMAN174's Avatar
What size are you looking for? Michelin makes many different versions of their LT tire. We went from BFG e rated to Khumo d rated for the price that fit the budget and they still could hold the weight without being at max pressure. I run mine between 55-60 lbs.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 02-17-2015, 10:44 AM   #4
wyo700's Avatar
I put the Michelin LTX AT 2 on my tundra in a load range E. Best decision ever with my camper hooked to the back. Truck feels very solid now. With everyday driving the tires are quiet and smooth and I have not run into any issues off road. Get load range E you won't regret it.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 02-17-2015, 10:55 AM   #5
New to Forest River
Roving Ron's Avatar
I have the same tires my Tundra and find towing much smoother with them.
Be aware that these tires run at 80 lbs and the TPMS on the Tundra are not rated for that pressure. I have aftermarket TPMS that is rated for 150 lbs so I feel safe.
Grey Nomads, Ron and Sue
Grey Nomads:l Ron & Sue
Roving Ron is offline   Reply With Quote
Old 02-17-2015, 11:03 AM   #6
Commercial Member
Thanks in advance.
What is your GAWR for the rear axle? (info on tire placard)
What is your actual scale weight on rear axle with the Wildcat hooked up when it is fully loaded as you would be for a long trip?
What is the OE tire size?
OE tire Load Range C or D ?
Without the above facts any answer is no better than a guess.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 02-17-2015, 11:38 AM   #7
Scootdawg's Avatar
I love my Cooper Discoverer HT3's
2014 F-150 SuperCrew
2015 Rockwood 8289WS Diamond
Scootdawg is offline   Reply With Quote
Old 02-17-2015, 11:42 AM   #8
Ret E-9 Anchor-clanker
donanddona's Avatar
Bought Continental LT's last year dumping the P255 that were on it. Lost half the cushion ride. Lost some more when I pump them up to 80psi for towing.
donanddona is offline   Reply With Quote
tire, tires
