Old 02-24-2015, 10:38 AM   #11
X2 on the Firestone Transforce
Kevin & Judy is offline   Reply With Quote
Old 02-24-2015, 01:03 PM   #12
Originally Posted by geotex1 View Post
Michelin LTX A/T or M&S, Bridgeston Dueler Revos, and Bridgestone Transforce are all excellent LT tires. Never had anything less than 80K on Michelin LTX, and they had tread left, just the compound got too hard and started to exhibit sidewall cracking. On my 98 K1500 Z71, never was there a more capable tire that the original LTX A/T on it - 265/75R16 on 16x8 aftermarket wheels! Regardless of any subjective arguments here from seat of the pants feel, the construction of an LT tire is one that is stiffer than a P-rated tire by design. You will notice a difference - period. However, you bought a TRUCK and not luxury sedan!
X2
rzrnaz is offline   Reply With Quote
Old 02-24-2015, 01:09 PM   #13
Originally Posted by TURBS View Post
Firestone transforce!
Best tread wear in the business as far as I'm concerned.
Ive driven well over 25k a year every year for the last 14 years.
I've tried others but firestone transforce tires are the ones I get the best mileage out of.
X3 good tires!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is online now   Reply With Quote
Old 02-24-2015, 01:28 PM   #14
William
WEMig's Avatar
Best bang for the buck also.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 02-24-2015, 01:49 PM   #15
Send a message via MSN to Tiggerdad
My 2013 2500 came with Firestone Transforce. Tread wear is even across but I currently have 19,000 miles on them and will be lucky to get 25,000. Lincoln's head is almost entirely visible. Will probably go to Coopers as I have heard good reports from them.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 02-24-2015, 06:44 PM   #16
Flagstaff15's Avatar
I dont know much about brands an such but I am learning fast from others. My dad said treat your tires better than your wife and they will save your life. I am sure hw meant the trailer as well as the truck.
Ron Fuller
Retired USPHS Capt O-6
2015 Flagstaff Classic Super Lite
8528IKWS
TV F-250 Super Duty
Flagstaff15 is offline   Reply With Quote
Old 02-24-2015, 07:05 PM   #17
(Dry Huunday)
DreiHunde's Avatar
I've had great luck with Transforces in the past. Currently have GY Wranglers AT Kevlars and after about 12000 miles they are looking pretty good!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 02-24-2015, 07:31 PM   #18
RPAspey's Avatar
I run the 10 ply Cooper AT3. About 30k on them and still going. I'm sure I'll get 55-60k on them. Great in mud & snow, but not super sticky on the asphalt. I had to cut my cornering speeds by 25%
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 02-24-2015, 07:43 PM   #19
I had a set of Michelin LTX M/S 2 18" on my 2012 1500 chevy crew cab. Great tire. I went with the load E range. When I was not towing I would air down to about 38 lbs and the ride was better than the factory Bridgestone Duellers. I usually ran about 65 lbs towing and never set off the tpms. I 1st put a set of the BF Goodrich TKO's, but swapped them out for the Michelin's the next day due to road noise. If you don't want to sacrifice the ride, Michelin is the way to go for the extra $$.
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 02-24-2015, 08:08 PM   #20
phat phrog stunt crew
I too had a set of michelin ltx m/s tires. Wore down to 3/32 and 4/32 in less than 30000 miles. Tire pressure checked weekly, tires rotated every 6 months along with alignment check at that time and performed if needed. To say I was po'd would be an understatement. Tire dealer claimed neglect until I plopped maintainance records onto his counter. He changed his tune quickly when he saw he didn't have a leg to stand on.
I am going back with them on the off chance I got a bad set. They are supposed to be 70000 mile tires. I got 29xxx out of them. I live in illinois, so no corners to carve. All roads lead to "T" corners or intersections. I have an old hot rod when I get the urge to turn tires into smoke. I drive and baby my truck like the proverbial old man.
They ride well, excellent traction in the wet/snow. My only bitch is the wear/mileage I got out of them. Will review again in 2 years if they wear like this again or if I remember... lol.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
tire, tires, truck
