Old 06-30-2016, 08:25 PM   #1
Tires for TV
I'm driving a 2015 Lincoln Navigator and occasionally pull a 34' Heritage Glen with a dry weight of approx 7000 pounds. Time to replace tires. Currently use a stock passenger rated tire. Thinking about a light truck tire but not sure how it will affect vehicle's suspension with auto load leveling. Any ideas?
Buzzard Bait is offline   Reply With Quote
Old 06-30-2016, 09:57 PM   #2
Usually Confused Member
emm-dee's Avatar
Just get a 10 ply rated E-load tire. Stability while towing will be remarkably improved.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 07-01-2016, 10:16 AM   #3
Since you pull infrequently I would replace with the same stock tire since you seem to have no complaints.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 07-30-2016, 11:51 PM   #4
Tires
The current tires are P Metric. Many posts suggest a LT tire for better stability with this size trailer. Tires are 275-55-20. Only LT in that size seems to be BFG all terrain K02. Looks like pretty aggressive tread. Wondering about ride and noise when not pulling. Yokohama has a XL rated with a 2800 lb max load.
Old 07-31-2016, 09:20 AM   #5
XL's are smarter way to go. LTs are to much for your navigator IMO- loss ride quality and noise. I wont run LT's on my tundra because I know It will ride bad - for what I tow Im ok with alittle wiggle.
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
Old 08-01-2016, 10:30 AM   #6
raspivey's Avatar
I tow 7300 lbs loaded with a Tahoe, so I can relate. I run Nitto 420S XL rated in the rear at 45 PSI cold and it handles great. I drop to 35 PSI when not towing and have a stock ride.
Old 08-01-2016, 11:23 AM   #7
acadianbob's Avatar
I think LT's aren't a good idea for your vehicle; especially E rated. You would be unhappy.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 08-04-2016, 12:32 PM   #8
Sham183
mopwr4me2003's Avatar
How long have you had these tires? I am looking at the exact same ones and wondering how they ride and are wearing.
I don't want to kill the ride on my traverse so I have decided against the LT tires for now.
Tim
mopwr4me2003 is offline   Reply With Quote
Old 08-04-2016, 03:27 PM   #9
raspivey's Avatar
Tim
I've only had them for about a month, but I've had good luck with Nitto. I ran them on my Camaro and now I run them on the front of my Vette. I'd put them on the back, but they don't make a drag radial in my size so I had to go with Mickey Thompson.
The ride is as good as stock on the Tahoe at 35 lbs. I've got nearly 900 lbs TW and 45 PSI felt good and rode like stock when towing. Unhitched I definitely notice the rougher ride at 45 lbs.
Old 08-04-2016, 08:17 PM   #10
Sham183
Thanks for the info this helps.
Tim
tire, tires
