03-20-2019, 09:32 PM
Titan Replacement Tank
Anyone replace the miserably small 28 gallon fuel tank in their Ram with the Titan 51 gallon tank? Issues? Complaints? Love it? I have a 2015 Ram 3500 mega cab and am looking to stretch my leg time and only fill after dropping off the camper at the camp site while still saving bed space.
03-21-2019, 10:06 PM
Failure is my business
About the only thing with replacing the OEM tank with a larger unit is I don't think you'll be able to reprogram the distance to empty to be correct. Otherwise it shouldn't be any issue.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
03-22-2019, 09:08 AM
If you have a diesel truck I would go to "Turbo Diesel register .com" and ask your question there. I have not kept up on the fuel tank sizes on the newer trucks. My 2008, Dodge 6.7L Cummins, 2500 Mega Cab has a 34 gallon tank which is one (1) gallon smaller than the Crew Cab Long beds tank which is 35 gallons. If I was to add a tank it would replace the spare tire and fit in this cavity. In The 124,000 miles I have driven my truck I have never needed to use my spare tire.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
03-22-2019, 11:10 AM
Remove the spare and replace it with a tank and the chances you'll need a spare will skyrocket
03-22-2019, 02:30 PM
The next time I buy new tires I’ll have to take the spare down and put my best tire in its place. I imagine that the brand new spare is probably rotten
03-22-2019, 03:04 PM
Thanks for your input. I called my Ram dealer about the DTE adjustment, and they started talking in circles. I think I'll keep the spare, I'm not the most fortunate person on the planet. Last flat I had, I had no spare and while I waited was hit by four deer ticks and ended up with Lyme Disease.
1989 Viking Li'l gasser Pop up
1993 36’ Thor Class A
2009 16” Kodiak Cub Hybrid
2010 24’ Fleetwood Pegasus
2017 24’ Flagstaff Shamrock 23IKSS
2015 Ram 3500 Diesel MegaCab 4X4 SRW
03-23-2019, 09:38 AM
My spare tire was new in Oct, 2007 when the truck was built. This has never been replaced in fact my towing tires are larger now so, it would not even work anymore on my truck. The lowering cable does work since I had to move the tire to clear the 5" exhaust.
Jim W.
03-23-2019, 10:04 AM
I have a 2015, 6.7, Ram dually 3500, replaced the OEM 28 gal with a 55 gal. No other modifications necessary although the fuel gauge doesn’t correctly reflect current half . I can go about 150 miles before the gauge moves off of full. But you can get use to it
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3600RS
03-24-2019, 09:21 AM
Thank you. Did you reprogram your DTE computer? My dealer gives me the blank look. It seems as though techs are getting less and less skills in "problem solving".
03-24-2019, 09:45 AM
Sorry no, never thought about it. Just by driving, either pulling or not, I have been able to determine when to refuel based on the fuel gauge and territory. I use an app for mpg when I refuel
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3600RS
03-24-2019, 04:44 PM
My spare is probably rotten, truck was built in 2012. Nothing goes in my truck bed but the hitch and the auxiliary tank. I could put the spare tire behind the hitch. I wonder what a tank costs that is installed in place of the spare tire
