Old 01-30-2013, 11:58 PM   #11
Roadie66's Avatar
You may want to look at Super Springs they worked for me.
Home is where the hookup is!!
2011 Silverado 2500HD Duramax LTZ tailgated by a 2012 Crossroads ST25RB Reserve
Roadie66 is offline   Reply With Quote
Old 01-31-2013, 08:33 AM   #12
MtnGuy's Avatar
Originally Posted by DougP47 View Post
mtnguy .. I have an equalizer hitch with 10000 bars.
I presume you mean 1000 lb. bars. They may not be enough for that trailer.....the website lists a 980 lb. empty tongue weight.
Another concern with that kind of tongue weight.....make sure your reciever hitch is rated for more than the actual tongue weight. A trip to the scales will reveal that, or do the bathroom scale weigh-in. Determining Trailer Tongue Weight | etrailer.com
I think the problem the coil springs on the truck are designed for a smoother ride than heavier loads.
Yes, that is a problem with coil springs.
The truck sets about 1" low in the rear if I set it up per equalizer destructions. As far as scale not yet but the trailer sets level at this adjustment. I have tried the set up from the dealer and change that the day after I brought it home. I might just have to take it to the scales when the weather breaks before doing anything. thanks for the info.
Just because a trailer sets level does not mean the WDH is setup correctly. The trailer tongue height is adjusted by the ball height. Yes, a WDH will bring the trailer tongue up some, but the main adjustment for the trailer to ride level should be the ball height
Old 01-31-2013, 06:39 PM   #13
DougP47's Avatar
Originally Posted by jeeplj8 View Post
I must not have read the link correctly, they include new rear coil springs? Well then that price does not sound bad.
But if you are only getting 1 inch of squat, that sounds perfect, I would not need with anything.
jeepij8 that would be 1" from front to rear finder.I have the hitch ball height set real close i think. I will try to weight it after the weather breaks. thanks for the input guys
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 02-01-2013, 12:37 AM   #14
Air Lift 1000's on my 2012 Ram 1500 works great ! $89 with free shipping . 3 hour install by me with lots of breaks . Love them . Jim
FarmerJim is offline   Reply With Quote
Old 02-01-2013, 09:13 AM   #15
daydreaming about camping
jeeplj8's Avatar
When setting up any WDH, you need to get some good measurements before you start, and then always measure at the same place. Most install specs I have seen recommend you measure at the wheel well to find out how much movement you get, both front a rear axle.
Generally, you want the rear wheel well to sit at least 1 inch lower than unhooked, and the front to be about level. That is optimum.
What are your unhooked measurements and hooked up measurements? The only way to truly tell how good your WDH is working is to weigh it on a CAT scale that will give you the front (steer), rear (drive) and trailer axles independently. You may find the results surprising.
I would get all that information before I started investing time and money in supplemental springs or helpers. You may not need them, but more importantly, you may be covering up the real problem.
I know the current generation 1/2 ton trucks (without the max tow, etc packages) and actually sprung softer than older generation 1/2 tons. My 97 1500 Ram did not squat more than inch until trailer tongue weight was around 1200 lbs. but most are designed to give a little quicker now for ride comfort.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 03-08-2013, 07:56 PM   #16
DougP47's Avatar
Ok here is the measurements I have with tt and family in truck
Steer axle 3440… drive axle 2680..
With tt hooked up and equ-a-lizer hitch.
Steer axle 3180…drive axle 4000 tt 6600 lbs
Does this look go to you guys? Any help would be appreciated. thanks
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 03-08-2013, 08:08 PM   #17
Dave_Monica's Avatar
For clarification, the first set of weights is for the truck loaded, but no camper and the second set of numbers is with the camper hooked up with equal-i-zer bars in place?
Dave
Old 03-08-2013, 08:12 PM   #18
DougP47's Avatar
Correct but i had a full house in the truck. GF two dogs and cab on truck bed. Only thing missing on camper weight is 2 honda generators.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 03-08-2013, 08:36 PM   #19
Comparing the 2 sets of numbers you've added 1320 lb to the rear axle and reduced 260 lb from the front axle weight...not good. Unfortunately what's missing would be the weight with the camper hooked up but without the hitch bars snapped up...that would indicate weight before any re-distribution.
I don't think that the hitch is transferring near enough weight to the trucks front axle and the camper's axles. You need to try adding another washer or two to the hitchhead to angle it down more and then re-weigh. I'd rather see it set that you're not reducing the truck's front axle weight as much...should be less than 100 lb IMHO.
Dave
Old 03-08-2013, 08:50 PM   #20
DougP47's Avatar
Dave thanks for your input. I did notice the difference in the steer axle. I currently have 3 washers on the hitch. Also as a side note when i weighted the tt hooked up i was not in the truck. I had to get out this time to hit the call button to get my weight.
oops i weight 250 hope that will bring it closer. I will get it weighed again workout the bars hooked up still hooked to the tv correct? I don't think I need to weigh the tv again I will have a full tank again before weight in.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
