Old 11-07-2012, 09:56 PM   #21
Twisty's Avatar
I put a B&M remote tranny filter and a drain fitting in the pan of my Ranger.
Drain, refill with synthetic.
Repeated 2 more times. Changed the filter once a year.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 11-07-2012, 10:22 PM   #22
jimh's Avatar
mine recommends change at 36000. i have complied with that. have it flushed at the dealer for $100 usually a little less than once every 2 yrs.
the dealer will tell you if u haven't been changing it, changing it can make problems show up. mine has 160k and hasn't given a problem.
on my truck, flushing it is abt the only way to get it all changed.
i haven't looked but don't believe my torque converter has a drain plug on it (i haven't pulled the cover to check).
my recommendation would be to change it per manufactures service intervals.
jimh is offline   Reply With Quote
Old 11-08-2012, 05:15 AM   #23
Witch Doctor's Avatar
Originally Posted by Len & Cheri View Post
I don't know of any manufacturer that says you don't have to change the fluid. I follow my owners manual and change at recommended mileage. What does you manual say?
I agree, It is very important to change your fluid. You will also need to change the filter and clean out any metal chips that will collect on the magnet. That will also indicate to you your wear and tear. Also then replace the seal to the pan. Keep a record, because if you have a break down under warranty they will not honor it by saying you did not do the recomended maint.
Old 11-08-2012, 06:29 AM   #24
Wanna Be Camper
SaskCampers's Avatar
Do it by the book as has been said a bunch of times. You won't go wrong using the manufacturer schedule for pretty much anything on a truck or car for that matter.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 11-08-2012, 09:53 AM   #25
IMHO, my best advice is:
What does your owner's manual say? Then be as good or better than they recommend.
Remember your warranty, weight the cost of oil and filter against a new tran.
traveler2955 is offline   Reply With Quote
Old 11-15-2012, 10:32 AM   #26
Incheon, S. Korea
BigBaron's Avatar
As a former Porsche tech, I can say I've never seen a problem with changing the tranny fluid. Flushing? That's a no-no! Fluid and filter is all you need.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 11-15-2012, 11:13 AM   #27
Bakka323's Avatar
Thanks for everyone's input on this! I recently got all fluids changed and cost around $500 but I can rest easy that everything is up to date!
2006 Nissan Xterra 4X4
2013 Surveyor SP-189 Cadet
Bakka323 is offline   Reply With Quote
Old 11-15-2012, 12:04 PM   #28
wyo700's Avatar
I was taught the same thing in school never ever flush.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 11-15-2012, 12:33 PM   #29
Herk7769's Avatar
I am sure "change" and "flush" are being used interchangeably here.
I doubt anyone would waste the amount of fluid required to actually flush out the transmission.
HAM CALLSIGN - KC3FFW
Old 11-15-2012, 12:43 PM   #30
wyo700's Avatar
Maybe but I am not using them as the same. Power flushing can potentially ruin a transmission.
2013 Toyota Tundra
