Old 11-03-2011, 10:59 PM   #11
62car9's Avatar
[QUOTE= My feelings, is if the trailer is over 8000 lbs. I would go diesel. Wayne[/QUOTE] X's 2. If fact was just looking at a left over 2011 Sierra diesel / allison. Give ya a great deal on a 2010 gasser
2011 Crusader 290RLT
2010 GMC 2500HD 6.0
Nights camped in '11 - 35
62car9 is offline   Reply With Quote
Old 11-04-2011, 06:49 AM   #12
dretired's Avatar
Originally Posted by Wumba View Post
Dry weight around 6800 lbs. Gas or diesel is 14k lbs. in a 2500HD. I can afford what I want. I just don't see dropping 50k for a new TV that will be used solely for towing, ergo the 2007 or 2008 diesel model. The model year will be newer should I decide ga.
Wumba... It would seem to be ok to go with a gasser for towing the trailer that you have now. BUT could you ever up grade in the future to something bigger and heavier ?? Or go Blazing over the Rockies !!! I agree on NOT spending 50k +.. for something thats used for a few thousand miles a year.. Good luck in your decesion
dretired is offline   Reply With Quote
Old 11-04-2011, 07:25 AM   #13
Campster's Avatar
i would go diesel...If you ever go even bigger on your trailer down the road you will be all set up. That 50k figure is MSRP pricing. There are some great deals on 2011's right now if looking new, which I would recommend. These diesels really hold their value which makes the used ones quite expensive too. I recently went diesel myself, Dodge 2500 Bighorn Long Bed MSRP over 50k, negotiated the price down to a little over 39k. Still a lot of money, but this truck will be around for quite a while.
Campster is offline   Reply With Quote
Old 11-04-2011, 07:30 AM   #14
Look at how often and how far you think you will be towing. If less than 10 times a year, a gasser with the right rear end will do fine. If you will be on the road weeks or months on end then stick with a diesel.
It looks like the v-cross max weight is under 8300 lbs. My camper comes in about 9200 lbs.
I have a F250 6.4L. I am looking at downgrading to the F250 6.2 Gasser with a 4:30 rear end. It can tow 11,200 lbs from the tail or 14,000 lbs goose/5th. The cost of diesel and the cost of maintaining it and for using it as a daily driver no longer make sense.
Depending on brand loyalty and your specific cab needs you could pick a brand new 2011 F250 6.2 Super Cab up for mid $30,000...
Also, the new Eco Boost F150 when configured correctly can pull 11,300 lbs. There are several threads reviewing results of towing with it.
To me ,it is no longer a diesel vs gas question. It's a question about your requirements: weight, frequency of use, distance of use, type of use, etc that should be determining factors on what tow vehicle you choose.
2015 Ford Expedition EL
2012 Salem Hemisphere 312QBUD
buckeyefan is offline   Reply With Quote
Old 11-04-2011, 11:11 PM   #15
flyrotor's Avatar
I bought a diesel this year, did I need it, no, would I do it again, absolutely yes!
My trailer is maybe 7500 loaded, any gas 3/4 ton would not even blink at pulling it, my 1/2 ton that I used to have worked hard but was definately capable, just not to my likings.
I bought diesel because I that's what I wanted, no math involved in MPG versus purchase price or fuel costs.
I have never looked back, I am very pleased with my purchase!
flyrotor is offline   Reply With Quote
Old 11-09-2011, 10:21 AM   #16
I owned a 2010 GMC 2500HD with the 6.0L gasoline V8. I traded it for a 2011 Chevy 2500HD with the 6.6L Duramax diesel and the Allison 6 speed transmission. Obviously the initial investment along with routine maintenance costs for the diesel is higher. However, in my opinion the diesel is a far superior vehicle. Fuel cost is about a wash, my diesel gets better fuel mileage than the gasoline in both towing and non-towing applications (easily enough increase to make up the 8% - 10% difference in fuel cost), my wife believes it is quieter, the ride is better, and in a drag race the diesel will walk away from the gasoline.
Jerry, Johnnie, CC, Dixie Rose, and Beau
2012 Cardinal 3450RL - TrailAir Rota-Flex Pin Box, Equa-Flex Equalizers, Level Up Auto Level, Winegard SK-3005 Satellite System
2011 Chevy 2500HD - 6.6L Duramax, Allison Tran, Husky HD Aftermarket 5/1 Springs, Air Lift LoadLifter 5000 Air Bags, Drawtite Pro Series 20K Fifth Wheel with Square Tube Slider
NJAg78 is offline   Reply With Quote
Old 11-09-2011, 10:43 AM   #17
jimh's Avatar
i bought diesel in 2002. you can't justify it on cost of fuel because fuel filters and more frequent oil changes (at $50 ea at the dealer) will out weigh the fuel savings.
the plus on the diesel, besides the low end torque, is that there isn't that much difference when u get the tow package. believe the only added thing is the wiring and plug. radiator and trans oil cooler are already there.
resale could go either way: the early 90 Fords actually carried a penility for the diesel.
should u buy used, i would make sure the radiator maintenance was done timely and the right additives or antifreeze was used. i personally don't want an engine that has been chipped.
jimh is offline   Reply With Quote
Old 11-09-2011, 12:19 PM   #18
If money was no object I'd have a diesel for sure, but I can't justify it for the amount of times I tow and my TT. I will go for the Ecoboost for my next truck though.
Len & Cheri is offline   Reply With Quote
Old 11-09-2011, 03:19 PM   #19
hatstomper's Avatar
We had an 08 GMC 2500hd 6.6 Duramax. Great for pulling but had a GVWR (9200lbs) problem. When the truck weighs in at 7524 and the add 1704 pin weigh in the box, thats a problem. We took Herk's idea and bought a Chev 3500 (SW) standard box Duramax. GVWR is 11500 so no problem with that now. But plain and simple, if you tow alot a diesel is the way to go.
2011 Chev 3500HD LTZ Duramax
2013 Sterling 32RK
Hijacker double pivot slider
hatstomper is offline   Reply With Quote
Old 11-09-2011, 03:31 PM   #20
At my age, the gas engine will last me the rest of my life, and since my last 5th wheel is 3 ft. longer with a slide (and 2000 lbs heavier) won't ever be buying a larger trailer. Wayne
wayne anthony is offline   Reply With Quote
