Old 07-13-2015, 03:22 PM   #11
Old Member
A SRW 1 ton 4 door CC short box is gonna weigh in around 8,400 lbs. ready to travel. That will allow you 2,600 - 2,800 lbs for your hitch. That would be my starting point.
Cool Canuck is offline   Reply With Quote
Old 07-13-2015, 03:37 PM   #12
New here, but my dually is a daily driver. Love the Duramax/Allison combo and liked the Fords I test drove as well.
Pros - in Texas, there are many many duallys even in the city. Stability is fantastic. Very comfortable drive at highway speeds loaded or not.
Cons - Back into most parking spots or park out a ways and pull through. Get as high as 23mpg at 55 mph highway speeds. Only 17 mpg at 75.
Personal note: We got tired of always stepping up in class to get more payload and capacity. Finally went straight to the top and don't regret it.
TexasFamily is offline   Reply With Quote
Old 07-13-2015, 03:53 PM   #13
BamaBob's Avatar
We have been test driving 1T 3500 RAM trucks - I have driven both the SRW & DRW (and 8' bed versions at that! )
You know what? I could not tell the difference between the DRW/SRW! Neither could the DW when she drove it and backed it up. I could totally see this as a daily driver (and if we go FT in 2018 it WILL be the DD ) The ride is great (we are looking at a Laramie Longhorn) and just as comfortable as out current Truck.
Unless your daily commute is downtown NYC or the like, what's the deal? shoot, even with the F150 we find ourselves parking in the "Truck parking lot" when we go to the stores and malls. Besides, the walk will do ya good!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-13-2015, 04:55 PM   #14
Chewie's Avatar
Dually. As a matter of fact, my combo will be for sale in favor of a motorhomes. 14 Ram 3500 Dually, 14 Heritage Glen 5er.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 07-14-2015, 12:05 PM   #15
I have had both. I had a dually that was best tow vehicle I had far as stability and confidence. The outside duals track in the same tracks as the trailer tires was the first thing I noticed. Much easier pulling trailer and keeping in you lane. As far as around town and parking it really was not any harder than the 2500 with the same lenght bed and cab. The overall length of truck gives me parking problems more than the width. As a side note you don't get bullied nearly as bad with a dually as you do single wheel. You are less likely to need air bags on a dually compared to a 2500. If you are around 2000 pound hitch weight a 2500 will sit down on the overloads or real close and those over loads are harsh. The 3500 can go over 2500 no problem at least that is high as I have pulled and it did fine. Not going by spec numbers but from past practice. Some of the new 2500's have air ride also and that may be a good deal don't know.
Ke5rbd is offline   Reply With Quote
Old 07-14-2015, 12:28 PM   #16
B and B's Avatar
I just bought a SRW F 250. Daily Driver for me for 10 more years and parking was a large concern. This truck will tow 16,000 as long as I keep the pin weight reasonable. Will do just fine and does provide upgrade path from my current Rockwood.
They are doing a Super Duty redesign soon and everyone know boys love their toys so this truck will last till I retire!! in 10 years so the DW says..
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-14-2015, 01:08 PM   #17
I went through 4 dually extended/double cabs, gas (chev 454) and diesel (Ford 7.3, 2 Cummins 5.9) and now have a SWB GMC 2500HD Duramax. Towed 5er's with all, and hay trailers with all. Dually makes big difference with ball hitch hay trailers, but little to none with a 5er. If I had to trade I would go for a SWB SRW GMC 3500 Crew Duramax with my current Super Glide slider hitch, unless I needed more pin weight capacity. Main issue with a dually is how much casual driving you will do. If you plan to use it for grocery shopping, visiting the casino, going to ball games and such, a dually is a real pain. If commuting back and forth to work, parking in a large parking lot, and towing - no real problem. If you might want to tow a ball mount 14k hay trailer, dually is a no brainer. Also, if you would like to look "studly" while tooling through Sonic, dually is best.
RubberNail is offline   Reply With Quote
Old 07-14-2015, 01:23 PM   #18
I'll be the oddball and say SRW 2500. I have a 2007 Chevy Classic Duramax crew cab 2500. Just bought a 2015 Chevy Duramax crew cab 2500. Both pull our Sandpiper 365SAQ quite well.
When I was looking at pickups, I am almost positive that the 2500 and 3500 SRW short bed crew cab trucks both had the same 5th wheel trailer capacity of 17,500 lbs. I think the only difference was the 3500 has overload springs.
There is a huge difference between the 2007 and 2015 on how they handle the trailer. Both have airbags, but the exhaust brake on the 2015 helps here in the west with mountain passes. I have to sometimes accelerate down hills!
I use both of my trucks as daily drivers and really didn't want the 8' bed. I also am a farmer and a DRW is worthless in mud and snow. These are my work trucks, so for 15% of my total miles, I get along just fine with SRW. They also pull much heavier gooseneck trailers and I have not found myself wanting a DRW yet
jkdairy is offline   Reply With Quote
Old 07-14-2015, 01:38 PM   #19
CWSWine's Avatar
My yellow sticker said 3744 and on the scales loaded to go camping was 8200 lbs and my CCC according to the scales was 3200 lbs.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 07-14-2015, 04:56 PM   #20
Hi the dully wheels are a real trip in the winter snow. The truck has way to much tire in the back for its weight. In snow the rear end floats on top of the snow and dose not sink in to get a good bite. This makes the truck very hard to drive in the snow or if there is a lot of water on the road it will hydroplane. With the tt on the back it is very stable and you don't get blown around much. Make sure you get a limited slip rear end! If it is a standard rear end you can get stuck on flat wet grass old truck this was a big problem. Or 4 wheel drive but gas mileage will suffer.
hope this helps Tim
TimVWulp is offline   Reply With Quote
