Old 07-13-2015, 01:16 PM   #1
RollingDownTheHighway's Avatar
to dually or not to dually
We started looking at 5'ers this weekend to upgrade our TT. They're ranging from 34' - 38' footers. They're grossing from 15 - 17k. I know that a dually would provide stability, but the truck will also be my daily driver, which I drove mostly to baseball practice and some non camping weekends.
At what size and weight should I really consider a DRW over a SRW? I'm looking to upgrade to my 2014 1500 as well to a 2500 crew cab or maybe a 3500 with a larger payload depending on the 5'er
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 07-13-2015, 01:22 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
For stability the 1 ton dually is great but for a daily driver I'd think about the 1 ton SRW. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 62
Old 07-13-2015, 02:49 PM   #3
The 3500 SRW is a good option if you really dont want a DRW. The 5th wheels tow so stable already. At that weight, you will need a 1 ton, regardless. If you go 3500 SRW and find that you need more load down the road, 19.5 wheel/tire conversion is a great route. I had that on my 09 3500 and the load rating was crazy and the tires last forever.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 07-13-2015, 03:03 PM   #4
I have had both and wouldn't do with out a drw for towing ,only draw back is parking lot.
Matt & Sondra
2016 Sierra 377flik
2003 F350 6.0 Powerstroke
Curt Q20 hitch
k8mlp is offline   Reply With Quote
Old 07-13-2015, 03:30 PM   #5
When in doubt go with a dually!
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 07-13-2015, 03:40 PM   #6
Pauls Toy Hauler's Avatar
The dually will be the 'answer all' when it comes to towing. Higher payload, lower differential gear, and most likely a larger tank. With the weights you are talking about, DRW will be your best option plus leaves room for upgrading. Your only negative is just going to be fuel consumption when not towing. It's still going to suck.....but who are we kidding...we don't get into RV'ing to save fuel.
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
Old 07-13-2015, 03:45 PM   #7
jtstromsburg's Avatar
Love my dually. After years of pulling many different trailers, and two years pulling my model trailer with an f250, I went to a GMC 3500 drw. It's so much more stable, tires seem to west much better (that'll help with the need to buy two extra when it comes time), and I love the milage I get with my duramax/Allison combo. Unless you live in the city and parking is an issue, can't go wrong with drw.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-13-2015, 03:46 PM   #8
With the Chevy/GMC, all the HDs have a 38 gallon tank regardless of 2500, 3500 SRW or DRW as of 2008 and newer.
Paul, I like the upgrading down the road! LOL He's already looking at up to a 17K unit..... Not much bigger then those! LOL
Doc
Old 07-13-2015, 03:51 PM   #9
Having towed my current trailer with both a 3500 SRW and my current DRW I'd say go with the dually. I find it much more stable through bumps, on the SRW if hitting bumps on a corner you would feel side to side sway. With the dually it's solid.
Of course as mentioned parking in a parking lot is interesting. My crew cab long box dually is a daily driver. Haven't regretted it yet, just park further from the entrance when going to the mall or work.
2017 GMC Sierra Denali HD
2014 XLR Hyper Lite 30HFS5
Toys-
Yamaha G9 Golf Cart
2010 Harley FLHX with lots of mods
bowtie_guy is offline   Reply With Quote
Old 07-13-2015, 04:01 PM   #10
mud yapster's Avatar
With srw you will want to pay special attention to GVWR. Also the weight on the single rear tires. Also 3.73 or 4.10 rear differential to get you tow rating, gas or diesel also will matter.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
