Old 05-23-2016, 06:55 PM   #161
CWSWine's Avatar
Originally Posted by Blackrock View Post
On our second day out with this under rated 2016 Ram 1500. So far pulling like a horse, running like a top, sucking up EB and PSD Fords and spitting out bolts. Pulled Soldier Summit out of Price Utah today and left an older Ram 3500 in the rear view mirrors. When we hit I-80 at Crescent Junction to Green River with their 80mph speed limit I just set the cruise at 72 and let her stroll for the 20+ miles to where we got on NB 191/6 again.
No one ever said it won't pull it - They said you were 500 to 1200 lbs over rear axle weight ratings. Heck - the Hemi should pull that little 5er just fine. It's the payload rating in that light duty Ram 1500 you driving is the problem.
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
Sold - 2014 Cougar SGS
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 05-23-2016, 07:13 PM   #162
Blackrock's Avatar
I had to cut my load back a LOT. The front compartment and pass through got weeded out by 300# and the two Honda Gens are riding on the back bumper on custom made trays built by a retired master welder. Truck bed is empty as well.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 05-23-2016, 07:24 PM   #163
Just man up and get a 3500 CTD. Then you can do 75-80 mph. Wouldn't that be cool?
Plus you could load anything you want. Like a couple extra China bomb tires.
goduc is offline   Reply With Quote
Old 05-24-2016, 07:42 AM   #164
So, it has 1 horsepower, stops running every minute or so like a top and sucks.... got it. We definitely need some type of award here on the forums for posts like this.
dustman_stx is online now   Reply With Quote
Old 05-24-2016, 07:51 AM   #165
First test Findings...
Well guys, this weekend I took the new truck (2014 Ford F150 Lariat, Ecoboost 3.6, max Tow Cap) for a test pulling "Glenny", a 2015 Heritage Glen 27RLS (7100 LBS). Maybe I'm not using the settings correctly because it showed that I was doing only 9.6 MPG. It pulled fine and I could hardly feel the weight. It didn't go over 2500rpm, stayed on 5th gear most of the trip at an average of about 70mph. My only concern is the low mpg rate. is there any other settings I need to adjust?
FreddyCamper is offline   Reply With Quote
Old 05-24-2016, 08:08 AM   #166
You're pulling a 7200lb wind sail behind you- you should be ecstatic that you got 9.6mpg because that is on par or a little better than most get with a gas engine. The EB is designed to get good fuel mileage while empty and pull like a beast when loaded. It doesn't do both at the same time. It takes fuel to make power. You'll be much happier if you ignore towing mileage and just go camping and have fun.
Old 05-24-2016, 08:20 AM   #167
That is my experience. I get 10-12 and have seen as low as 7. Wind plays a role! Head winds and tail winds! Make sure you have tow haul on and stay around 60-65mph.
2016 Rockwood 2703WS Sapphire
2011 F150 Ecoboost SCAB/3.55
Martsing is offline   Reply With Quote
Old 05-24-2016, 08:22 AM   #168
Thanks...going at it this weekend again...and alcohol WILL be involved (at the camping site)
Old 05-24-2016, 09:22 AM   #169
rmac04401's Avatar
What is GVWR if those new f150's. Are they greater than old ones. My 2002 is only 6500. Does not give much room for payload.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2002 F150 5.4L extended cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 05-24-2016, 09:32 AM   #170
My 2011 has a 7200# GVWR.
ecoboost
