Old 03-26-2011, 05:33 PM   #1
To heavy or not to heavy that is the question?
Can someone answer this simple question.
My wife and I are in the process of purchasing the new 2011 Rockwood Roo 23RS. We were originaly going to pruchase the new 2011 Rockwood Mini lite 2306. But our sales man(not working on commision) said that we would not have a problem pulling the Roo trailer. I explained to him that my Chevy Silverado 1500 4x4 has a V8 4.8liter and has only a towing capacity of 5500lbs. He and the owner both came back and said that the Roo's base/dry unit weight right now is sitting at 4298lbs(this is the unit on the lot we are buying). So they figure with an average of 250lbs per person(that would be my 4 year old, my wife and me) that I will not have a problem towing this.
Are they correct?
Will I have a problem towing this?
And last we are new to hard tops and have been a tenter for alot of years.
jpc4444 is offline   Reply With Quote
Old 03-26-2011, 05:41 PM   #2
kalik282's Avatar
If you really want to know what the Roo weighs, have them take it to a certified scale, full of water, propane, etc. That will give you real world numbers to base your decision on. (If they weigh it properly, they can even get you the actual tongue weight.)
On your part, take your truck (Full of fuel), and your family, to the scales. This will help you determine the amount of weight you can add (IE Tongue weight, camping gear, firewood, etc.) until you reach your GVWR.
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 03-26-2011, 06:47 PM   #3
prof_fate's Avatar
Define problem...
I have an expedition that is rated to tow 8100 lbs. The trailer is labled at 5436 lbs. I figure I'll be at the max GCWR (12,500) with ease...
The truck weights 5500. 2 adults, 2 kids, dog, WD hitch will add about 700lbs.
Add 30 gallons gasoline for 250 more. Trailer will never be empty - even if you skip the 400lbs of water you will have dishes, bedding, food, leveling boards, a rug, chairs for outside...you can add a lot lot lot more (grille, bike, charcoal and wood, case of beer...). I'm figuring 1000-1200 lbs will be added for that stuff (based on our popup and past camping trips). Over 2,000 lbs of cargo/people/fuel.
5500 plus 5400 plus 2000 is what? 12,900????? We're over weight, huh?
And we've got 2700 lbs more towing capacity than the weight of the trailer...and my kids are under 10 years old still...they'll grow and I doubt I'll shrink (even though I keep trying!).
Read the owner's manual of your truck - carefully. An expedition can tow/haul/GCWR 1000 lbs more if the options are different (rim size changes it by 500lbs!)
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 03-26-2011, 09:53 PM   #4
Triguy's Avatar
You should be fine based solely on the limited info you gave for your truck and your family.
But, its not actually that simple and if you want to be certain, please provide some more information:
What is your Chevy's GCWR, GVWR, cargo capacity, vehicle weight and weight of all the passengers as well as the cargo you carry in the bed?
What is the weight of the loaded trailer? Besides your best estimate of your own luggage and stuff in the trailer, add in batteries 60-120lbs, propane of 60lbs, any dealer add-ons, a little water, etc).
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-27-2011, 08:40 AM   #5
hoffkm's Avatar
Jpc4444,
My father has the same truck/engine combination that you have. Unfortunately GM put that package together more with fuel mileage in mind and not towing. My father tows a Puma 19R, a small but heavy trailer (I don't have specs offhand but they are on Puma website for comparison) and the truck struggles quite a bit. He cannot keep up with me and my rig on the highway.
In addition to having the dealer weigh the Roo I would ask to do a test tow before buying.
2011 Rockwood 2901SS Ultra Lite
2014 Chevy Silverado Z71---Hensley Arrow Hitch
my other toy---1969 Camaro 396 SS
hoffkm is offline   Reply With Quote
Old 03-27-2011, 09:59 AM   #6
One word answer, NO!
That mystical "base" or Dry" weight number that the salesman quoted you is just that, mystical. No one has ever seen that number in their life. Once you add things like AC unit, water, food, clothes, etc,etc,etc, that number will likely climb to within a couple hundred pounds of the trailers GVWR. And that will be so far over your trucks mythical towing capacity that it is not even funny any longer. Depending on where you live, I could see you in some situations with your foot on the long pedal and pressed firmly to the floor in first gear just to get up some hills. And I am not talking about large mountains. The hills of West Virginia for instance could stop you in your tracks. Go back to your original plan as long as the trailers GVWR is within your trucks towing capacity.
Old 03-27-2011, 12:09 PM   #7
Albuquerque, NM
Char_n_Kath's Avatar
I pull a 2304 with a V-8 Dodge Dakota, which also has a 5,500 lb towing capacity. Most of the time I have no problem - the power seems to only become an issue fighting strong head winds! The dry weight on our unit as built is 3,783lbs, compared to 3,519 on the FR website. I find it interesting that the FR website shows the 2306 with a lower dry weight than the Roo you are looking at. IMHO the dealer wants to sell you what's on their lot, not what you really prefer. IMHO you should buy the floorplan that you want, not what a salesman is directing you toward. And if the dealer has honestly evaluated your towing capacity, then you should have no problem pulling a 2306, which has a lower factory-listed dry weight than the Roo.
Charlie
Charlie & Kathi
Albuquerque, New Mexico
2011 Rockwood 2304
2013 Dodge Ram Laramie 4x4
Char_n_Kath is offline   Reply With Quote
Old 03-27-2011, 01:55 PM   #8
"One word answer, NO!
That mystical "base" or Dry" weight number that the salesman quoted you is just that, mystical. No one has ever seen that number in their life."
One word answers are seldom helpful.
The question mentioned that the base weight was for a camper 'on the lot', so it would be easy to check if that was the actual dry weight.
To flatly "advise" someone without a shred of backup information is less than helpful.
Old 03-27-2011, 02:22 PM   #9
Still questioning... driving wife crazy
First off I would like to say thank you to all of for your responses.
Here is some additional information that I have gathered on the Accu weight of the trailer as it was deliverd to the dealer (this includes the 2 empty 20lbs propane tanks and all of the options this was a show room model)
Here are my numbers.
Chevy silverado Crew Cab V8 4.8L short box 4X4
GVWR 7000Lbs
GAWRFRT 3950Lbs
GAWRRR 3950Lbs
GCWR 11,000Lbs
Rockwood Roo 23RS
4250Lbs Accu Weight (all options included)
GVWR 6,145Lbs
Thanks everyone
John
Old 03-27-2011, 03:12 PM   #10
A lot depend of the kind of travelling you will do. A mostly flat terrain will be very acceptable but if you are planning to tow in hilly country you will need power for sure. I have a mini lite 2011 model 1809s and we pull with our uplander equipped with a hd transmission cooler and an extra engine oil cooler. I have no problem at all to pull it. The van is never under stress. I pull in 3rd gear and maintain my speed at 55 mph. on highways
capucine is offline   Reply With Quote
