05-01-2017, 02:08 PM
#21
Originally Posted by 5picker
Any kind of grease will work.
Vaseline, KY Jelly, Lard or even snot would be better than nothing.
Bacon?
05-01-2017, 02:20 PM
#22
To lube or not to lube--trailer ball
Service manager where I go told me to use vaseline as it will wash out of your clothes.
05-01-2017, 02:24 PM
#23
Originally Posted by Mr Havercamp
Bacon?
EVERYTHING is better with bacon!
05-01-2017, 02:25 PM
#24
We are talking about something that moves very little but really does need some kind of lube to maintain a freely moving joint and prevent galling.
This nails it. I use a Goosebox and a B&W Turnover ball. Before every trip, a paper towel cleans the old grease and dirt off the ball. I always have a tub of grease around the shop, and about a teaspoon will grease the ball nicely.
Someone posted they would never grease the hitch ball. How do you stand the screeching and squalling that comes from a dry metal to metal connection? When mine is dry, I know it immediately because of the aweful noise it makes, plus, as someone else mentioned it will be galling the metal on either the ball or the hitch...whichever is softer. Just a tiny bit of grease makes a world of difference.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
05-01-2017, 02:29 PM
#25
Originally Posted by rotorhead1250
No lube. No sandwich bags. No dirt. No need. Never have, never will. My opinion only.
Because metal-on-metal is OK!
Do you put oil in your engines?
05-01-2017, 02:30 PM
#26
Originally Posted by HangDiver
Grease recommendations?
TIA
CRC White Lithium Spray Lube, in the ball socket. Wipe out occasionally, reapply, not as dirty as chassis grease. Easier / cleaner to store.
05-01-2017, 02:44 PM
#27
Do I put oil in my engine? Come on 325. Hardly the same thing.
Not really... but yet it is.
Every major manufacturer of hitch balls and couplers recommend and sell hitch lube. If they recommend it, I suspect there is a reason why.
05-01-2017, 03:14 PM
#28
Deleted
deleted
deleted
Deleted what?
05-01-2017, 03:17 PM
#29
Hitch ball cover with attached tether. The tether keeps it attached, while you use the ball. As soon as you disconnect, cover the ball with it to keep from getting grease on you.
https://smile.amazon.com/Fastway-82-...way+82+00+3216
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
05-01-2017, 03:23 PM
#30
code.org
Ball Lube
We have towed boat trailers, motorcycle trailers, dune buggy trailers, motorcycle trailers, toads, and travel trailers and have always used ball lube.
I currently keep a jar of this in the tool box:
https://www.amazon.com/Reese-Towpowe...ords=ball+lube
And use this to cover the ball when not in use:
https://www.amazon.com/111931-Class-...tch+ball+cover
My Dad always said, "Keep your balls lubed and then covered when not in use."
Randy, Mary, and Mojo
Rockwood Signature UltraLite 8329SS
2001 Dodge Ram 2500 Cummins Diesel / Allison Trans
2015-14 Nights, '16-90 Nights, '17-101 Nights, '18-146 Nights, '19-76 Nights '20-56 Nights '21-42 Nights '22-86 Nights '23-65 Nights
05-01-2017, 03:29 PM
#31
Old Coot, Sometimes it's better to just not say anything at all. You understand that I'm sure.
Matt & Kathie
2022 Cedar Creek
05-01-2017, 03:33 PM
#32
Easier to just delete the post completely.
05-01-2017, 07:40 PM
#33
Canadian Member
I just use good old Vaseline. Seems to work fine.
05-02-2017, 07:59 AM
#34
StlClay
Look up Reese Teflon Ball Lube on Camping World site. Great stuff made especially for what you need. We use it and love it
2014 MiniLite with
Nissan Frontier
05-02-2017, 08:34 AM
#35
I use anti seize compound.
05-02-2017, 08:35 AM
#36
Originally Posted by SeaDog
I grease mine and place a tennis ball over the greasy ball. its a good idea to wipe out the ball and coupler now and then and apply new grease
If you can't find a tennis ball,,, they make ball covers !!!
05-02-2017, 10:48 AM
#37
I just use plain old axel grease on the ball and pivot points on my Reese hitch. Takes most all the noise out of it. DW gets some kind of small plate cover to put on it when not hooked up.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
05-03-2017, 05:35 AM
#38
I've never used grease on a ball hitch. I've pulled horse trailers, hay wagons, flatbeds with heavy equipment on them, you name it. Never had to replace a ball or a hitch for that matter.
I've never lubed the hookup pins on my 3 point hitches either. Or the shaft of the stinger where it plugs into the receiver hitch. Or the receiver hitch pin. Never had to replace any of that stuff either, or any tractor implements.
I do run oil in my engines as a general rule.
It can't hurt to lube your balls. But this discussion gave me a chuckle.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
05-03-2017, 06:31 AM
#39
Desitin Diaper Rash Cream works very well !!!
05-03-2017, 08:02 AM
#40
I use wax paper folded over a couple of times. I bought the hitch ball lube, but if you put too much on it just picks up dirt. I found I was frequently adding just a little and was never sure if it was enough. Th wax paper is simple and clean.
