TOAD Problem - 2001 Wrangler
I set up my 2001 Wrangler TJ as a TOAD for our Sunseeker. I've tested it a few times a always run into the same problem. Occasionally when turning to the right, the steering wheel will turn to the max and the wheels no longer track behind our RV. It doesn't happen every time time, but even once is too much. The front axle has an automatic locker, so I'm not sure if that is causing the problem of if something else is wrong. Any ideas why this is happening?
