Old 06-26-2014, 09:43 AM   #11
KMP44's Avatar
Originally Posted by MuskyD View Post
I was told that my trip for the 4th of July most likely will not occur....are you kidding? I brought it in for the tongue jack repair on the morning of June 18th, I cannot expect to use the NEW RV on June 30 or July 1st. I bought this RV early May, used it once on Fathers Day weekend and the jack broke. Now I am told to not expect to use it for a 4th of July camping trip. Wow? Any input?
3-4 weeks for a warranty repair seems to be the norm...
One of our Trail Express tires completely seperated from the side wall in May. Called the dealer - he said bring it in on June 9th. FR agreed to warranty the tire even though it was a month past the warranty from Lionshead ( the tire supplier). Felt good about that - until 2 weeks go by and no tire. Had a trip planned and wasn't happy. The dealer "found" me a spare in the shop or off a used unit on the lot. So at least we could use it. Still waiting for the tire. So, net result, went 80 miles round trip to drop off. 80 miles round trip to retrieve with the loaner tire, still need to go 80 miles round trip to swap that for my new tire. Cost of that is probably more than the tire is worth.
And, the kitchen faucet also had an issue from work the dealer did in the fall. Not a warranty item. They had the part in 3 days and installed it the day it arrived. So, at least in this case, I do think the issue is with the factory. We've had no issues getting warranty items approved, but if parts are required, it takes a while.
I would try asking them if they have any way to get you going for your trip, and otherwise, the suggestion to buy a cheap manual jack is probably better than missing your trip.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 06-26-2014, 09:53 AM   #12
thebrakeman's Avatar
Tell them you are going to use the camper for the holiday, then bring it back. Instruct them to keep the parts on order, and make a new apt when they are actually ready to install. For the holiday, just install a cheap HF jack. After the powered jack is replaced, keep the manual jack as a spare.
thebrakeman is offline   Reply With Quote
Old 06-26-2014, 11:51 AM   #13
bikendan's Avatar
that's one of the advantages of NOT ordering the trailer with a power jack and simply installing one of your choosing, not the factory's choosing.
it's so simple to install and refurb units are so inexpensive, that if you do this, then you still have the factory manual jack as a backup.
it's a 15 minute job to install one.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-27-2014, 07:55 AM   #14
While we're on the topic, what exactly is the process for replacing a hand-cranker with a powered unit? I know about the 3 bolt that hold it in. More about what's involved to power the thing. Do you tap into the trailer's wiring? Or would I simply have another pair of wires to connect to the battery terminals each time I pull the camper out of storage?
Old 06-27-2014, 07:59 AM   #15
Just one wire, hook it to the battery terminal block, positive side. It should have an inline fuse.
Old 06-27-2014, 09:00 AM   #16
Thanks. I just dug some more, and see that the ground is handled thru the attachment bolts. Zip-tie this wire to the positive trailer main, and it should be pretty simple.
