Old 06-14-2012, 06:53 PM   #1
miatared's Avatar
Tongue weight ?
I found this site and it helped me in my quest to find out what my tongue weight was.
Use a bathroom scale, 2 pipes and some lumber. Provides a 4-1 ratio.
Link: Measuring trailer tongue weight with a bathroom scale
A photo:
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 06-14-2012, 08:19 PM   #2
MtnGuy's Avatar
Before I bought a Sherline, I used that method. Works great.
In my case, I used 2 small wood wedges instead of the pipes....I was afraid those might roll.
Old 06-14-2012, 08:35 PM   #3
Mark and Linda's Avatar
Might try this on mine to check the tongue weight, would two 2 x 4 blocks of wood work on this? DW said for me not to break her scales...
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 06-15-2012, 12:26 AM   #4
1l243's Avatar
I tried that did not even think about using DW scale. Picked on up at Goodwill for $3...It worked but the scale will never be the same... I would love to have a Sherline..
1l243 is offline   Reply With Quote
Old 06-15-2012, 07:32 AM   #5
MtnGuy's Avatar
Ideally, you should have 2x4s with notches cut out for the pipe both on the ground, and on the scales.....this would prevent the pipes from rolling, in addition the scale 2x4 on the scale would better distribute the weight, so that you would not "crease" the scales.
Old 06-15-2012, 12:30 PM   #6
1l243's Avatar
That looks good. At over 1000 lbs TW I needed a 5:1 ratio
Old 06-15-2012, 12:57 PM   #7
Your cheating,put the jacks up! Youroo!!
Old 06-15-2012, 01:23 PM   #8
1l243's Avatar
I was wondeing why my 13,000 lb trailer only had 10 pounds of TW....You gotta look close, they are not touching the ground...
Old 06-16-2012, 10:10 PM   #9
Interesting concept. Never would've thought about doing this. Wonder what type of contraption and ratio I'd have to use for a 14k lb 5th wheel?
bjlowe is offline   Reply With Quote
