Old 03-28-2015, 08:24 AM   #11
Originally Posted by thestrangebrew View Post
Quick question about the whole 11-15% target. That 11-15% is a percentage of what your trailer weighs for that specific trip and not the TT's GVWR correct? So that 11-15% will never be the same, unless you load up your trailer exactly the same every time right? Or is static? Example my TT gross is 6402 lbs so at 15% my TW should be 960 lbs every time because my GVWR is never going to change.
I've been wonder about what you said here because you would seem to be right, but I've been told that even if our trailer "we have the same 233S" is load to 6602 "spec" the TW is 602..........So what I did was add propane 40, battery 20, and WDH of 70 to come up with about 730 TW, at 730 my family and anything I need to put in the bed of the truck I would be close to my payload..........but at 960 I would be way over.
I'm thinking I might buy this also!!!!!
2016 Rockwood ROO 233S
2013 Ford F150 3.5 ECO SCREW
TT233S is offline   Reply With Quote
Old 03-29-2015, 02:54 AM   #12
Just a member
kandl's Avatar
Correct! But that doesn't mean you have to weigh the trailer every trip. Establish the weights with the trailer equipped for that gonzo excursion paying particular attention to what goes where in relation to the trailer axle/s. Maintain that process for lighter loads and you should be able to maintain that optimum tongue weight without having to plunk it on a scale.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
weight
