If you can, you should head back through a set of scales. You want to position your steer axle (front tires) on one pad, the drive axle (rear tires) on another pad, and then the trailer tires on the third pad. Take this as the first reading.
Pull off the pad, drop the trailer in the lot and go back with just the truck. Try to position it about where it was for your first reading, with the steer axle on one pad and the drive axle on the other pad. Take this as the second reading.
Now, if you take (First Steer + First Drive) - (Second Steer + Second Drive) you get your weight distributed tongue weight. This is effectively how much load you're applying to your truck.
Next, you want to compare First Steer to Second Steer. Ideally, they should be close if your WDH is setup right. More on First might be ok, but less on First is not. Based on your third photo, you have a lot of squat on the rear, so I'm suspecting you might be light on your steer.
Lastly, to get a true measure of how well your WDH is setup, hook back up to the trailer, but only on the ball. Leave the WDH unhooked and just put the bars in the back of the bed (ideally as close to the tailgate as possible). Go back and get a third measurement. This will give you your non-weight distributed numbers. Compare First Steer to Third Steer to see what the difference your WDH is making in your steering. Also, you can compare total truck (Steer + drive) to the second weight (steer + drive). The difference will be your non-weight distributed tongue weight. Add that to the trailer axles to get total trailer weight.
Lastly, if all this is confusing, you're in luck, there is help available. I keep three different sites (to give people options) book marked just for this reason:
Towing Planner - towing capability calculators
Travel Trailer Weight Calculator
https://www.huskytow.com/towing-calculator/
Edit: almost forgot. You don't need to go buy the sherline if you only need to measure once. There are directions out there for using a simple bathroom scale and some 2x4s to measure it. I recommend reading about it from this e-trailer site, since it covers several different tongue weighing methods:
https://www.etrailer.com/faq-how-to-...ue-weight.aspx
