Old 11-18-2014, 12:41 PM   #21
MtnGuy's Avatar
Originally Posted by Stormrider151 View Post
The hitch was set up wrong at the dealer. It looked good at PDI but it wasn't sitting level. We used it one time and looking at it on level ground it's a little tongue high.
Originally Posted by acadianbob View Post
If you are tongue high, that is definitely a problem.
acadianbob has brought up an interesting point. On a dual axle trailer, an tongue high attitude increases the tongue weight, as more weight is put on the rear axle. Getting the trailer level will help decrease the tongue weight.
Old 11-18-2014, 12:45 PM   #22
B and B's Avatar
Originally Posted by OldCoot View Post
For 150#, I wouldn't waste the effort. The scales could be off that much. The world won't come to an end and it sure isn't going to cause your truck any problems.
I am with OC on this... I am over by much much more... 150 lbs isn't much. Put the tank replacement and lithium battery dollars into E LT series slippers.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 11-18-2014, 06:04 PM   #23
Stormrider151's Avatar
I appreciate everyone's input and advice and I will be putting it to good use. I thought I knew what I needed to tow this trailer and quickly found out I knew very little. I've towed everything from a wave runner to a tiller ladder and never thought much about anything but hook it up and go. It's a wonder I'm still here. Thanks again. You have all been a huge help.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 11-19-2014, 07:30 AM   #24
... When I towed it the last time I had a real sway problem on the interstate. I'm hoping getting the hitch set up right, the dual cam and reducing the weight at the hitch will fix the sway issue.
If you are currently having a sway issue you do not want to remove weight from the tongue. Here is an excerpt from a write-up I did for a forum I'm an admin on:
The biggest contributors to sway, in this order:
1. Not enough tongue weight
2. Distance between rear axle and the hitch ball
3. Speed
4. Short wheelbase vehicle
5. Camper tongue is pointed up, not level or pointed slightly down.
6. Not enough pressure in the TV and trailer tires (they should be at or near their max sidewall rating)
7. Lack of sway control
8. Outside forces like side winds, etc.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 11-19-2014, 07:32 AM   #25
Can I as what you are towing with?
Reese Dual Cam. I spent about 3 hours adjusting mine a few weeks ago, then read about how it should be on the 5th link most of the time and mine is on the 4th. Next spring I'll be blocking off a few more hours...
2010 Chevy Suburban
Old 11-19-2014, 07:36 AM   #26
No Brian, I still have the P metrics on my truck. I don't drive much. It's a 2012 and has less than 24000 miles on it. That said my tires are in great shape and as bad as I would like to change to LT's I just can't make myself get rid of good tires. But you are absolutely right it would make a huge difference and maybe I should just bite the bullet and go ahead and do it.
Less of a difference than you think. When I was pulling a pup with a minivan I switched the van tires from P to LT and didn't notice any difference. That pup was a sway maniac and I did EVERYTHING to get it under control (except move up to a full WDH which I should have). Even took the spare tire off to get more weight on the tongue.
2010 Chevy Suburban
Old 11-19-2014, 07:40 AM   #27
+1
2010 Chevy Suburban
Old 11-19-2014, 07:59 AM   #28
Taranwanderer's Avatar
A pop-up is much lighter than the TT he's trying to tow. I'm not surprised that the switch from "Ps" to "LTs" didn't make much difference in your case. But change the configuration to an SUV with "Ps" towing a larger TT, and you'll see the difference. Pop-up was just too light for you to feel any change. You had other sway-inducing issues.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 11-19-2014, 08:10 AM   #29
It was lighter than his TT, yes, but it wasn't light. It was 3500 pounds loaded up, and actually heavier than the R-pod I replaced it with. Believe me, as touchy as that pup was, I would have felt any minor difference when I moved to the LTs. I could feel all the other minor tweaks I tried.
2010 Chevy Suburban
Old 11-19-2014, 12:56 PM   #30
I had a Coleman Niagara that dressed out at almost 4k. Started towing it with a sport track with air shocks. Finally had to get a used 1500 to pull it. Great camper but a beast weight wise for a pop up. Not nearly what I have now but still up there.
weight
