Old 06-06-2009, 07:37 AM   #1
Too Heavy?
I have a 2009 chevy 2500HD with the 6.0 and 4:10. I am about to purchase the sandpiper 316BHT. The hitch weight is 2099LBS, ship weight is 10712. Will I have any problems with weight?
bulldog25 is offline   Reply With Quote
Old 06-06-2009, 07:52 AM   #2
Additional info: Sorry to leave this out, it is a crew cab with the standard box.
Old 06-06-2009, 06:19 PM   #3
I am not sure about the 2009, but the 2008 2500HD Crew Cab 4x4 with a 6.0 engine and a 4:10 rear max tow capacity is 12,300 lbs.
If it is a Duramax Diesel 6.6 engine V8 Turbo, the tow capacity is 13,600 lbs with a 3:73 rear, a 4:10 rear was not available in 2008 according to my brochure. I have a 2008 1500 Vortec Max heavy duty 1/2 ton with a 6.0 engine and a 4:10 rear and my max tow rating is 10,400 lbs. My camper fully loaded is 7,910 lbs, I use a Reese WD&S control hitch and the truck tows GREAT. I don't think you will have any problem as long as the correct hitch is selected and It is installed correctly.
Old 06-07-2009, 09:11 PM   #4
rafcar's Avatar
With that hitch weight you may want to look into a good set of airbags.
2007 Forest River Cherokee 30F
* 14K Equal-i-zer hitch
* TST tire pressure monitor
2003 Chevy Silverado 2500HD Duramax
* 4" MBRP exhaust
* AFE stage2 air intake kit
* Hypertech III, set on stage1
* back-up camera
* Putnam XDR class V hitch receiver
* Airlift air bags
2004 EZGO custom electric golf cart
rafcar is offline   Reply With Quote
