Old 05-02-2013, 11:44 AM   #11
Originally Posted by mtnguy View Post
If you can push straight down on the nut, then it might not even be necessary for a torque wrench. It hard to justify spending a couple hundred dollars on a 500 lb. torque wrench that will be used on a couple of times a year.
As you all know, torque is measured in foot pounds. All of my 190 lbs. exerted on a spot 1 foot from the bolt axis is 190 ft/lbs. 2 foot from the bolt axis is 380 lbs. If I need to tighten the bolts on my hitch, I turn the shank over so that I have to push the breaker bar down to tighten the bolts. My 190 lbs. exerts 15.8 lbs. every 1 inch (190 divided by 12). If I need 300 ft/lbs, then I mark a spot on my breaker bar 19" from the bolt axis. (300 ft/lbs/ divided by 15.8). I then center my hand over that spot, put my knee on my hand, and carefully balance all of my weight there.
You can also use scales. I have a breaker bar with a union on it exactly 4 ft from bolt axis. Standing directly over the scales, and getting the breaker bar as near parallel to the ground as possible, I push down on the union until the weight on my scales show 115 Lbs......a loss of 75 lbs. (300 ft/lbs divided by 4 (ft) is 75 lbs.
The same goes with tightening the hitch ball to 450 lbs....for this I have to turn my hitch 1/4 turn to the right. My 190 lbs. minus 112 lbs (78 lbs.) is what should be showing on my scales using the 4 ft breaker bar, again making sure the bar is directly over the scales and parallel to the ground. Using the other method, I would need to put all of my weight on a point 28.5 inches from the bolt axis (450 ft/lbs. divided by the previously calculated 15.8 lbs per inch)
Only one correction mtnguy, to be technically correct, torque is measured in lb-ft, horsepower is ft-lb.
Old 05-02-2013, 11:55 AM   #12
fonzie's Avatar
OldCoot you might be correct, but all my torque wrenches are mark either foot/lbs or in/lbs on them.....
Fonzie
Old 05-02-2013, 12:01 PM   #13
It is a very common error, The SI unit for torque is the newton metre (Nm) or in English terms pound feet (lbft)
Old 05-02-2013, 12:08 PM   #14
fonzie's Avatar
Thanks, learn something everyday, which makes it a good day......
Fonzie
Old 05-02-2013, 01:26 PM   #15
thebrakeman's Avatar
ft-lb or lb-ft, same thing. There may be a standard convension, but they both mean the same thing, neither of which is a unit of power.
Horsepower is a unit of power, and is never stated in terms of ft-lb or lb-ft (which are units of torque).
The amount of power is expressed as so many "horsepower", or "hp", or some other unit of power (watt, Btu/hour, etc).
thebrakeman is offline   Reply With Quote
Old 05-02-2013, 01:33 PM   #16
From Horsepower - Wikipedia, the free encyclopedia
The mechanical horsepower, also known as imperial horsepower, of exactly 550 foot-pounds per second is approximately equivalent to 745.7 watts.
Old 05-02-2013, 02:17 PM   #17
buffalohunter's Avatar
Wow! He just wanted a suggestion for a torque wrench.
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
Old 05-02-2013, 02:19 PM   #18
Senior Moment
rockport's Avatar
Guess that's what they mean by TMI.
rockport is offline   Reply With Quote
Old 05-02-2013, 02:30 PM   #19
Well, my Haynes Ford manual refers to ft-lbs and my old import car manuals refer to ft-lbs. But I have seen it as lb-ft too. Some say tomato and some say tomato. Ft-lbs seems to roll off the tongue easier....
Just be glad you don't to deal with metric all the time. Very, very glad. Then you'd have to deal with things like kilopascals for air pressure, liters per 100 kilometers for gas mileage and yes, newtons for force. I can't stand it for the most part. Then we have mixed systems in use in Canada. Like lumber is sold in feet and inches like a 2x4 stud or 4x8 sheet of plywood. Canada officially converted to metric in the 70s. But if you went to a lumber yard and asked for a 38x89 mm stud they'd think you were nuts and ask you to go away. Some grocery store items are still sold in both systems. Go figure. 355 mL of pop anyone?
Give me miles, feet and ft-lbs any day of the week.
ps: when the heck did Ford go with metric?? Good thing because all my old tools are metric.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 05-02-2013, 03:30 PM   #20
MtnGuy's Avatar
Whoops. The correct term for torque is lb-ft, but many people (like myself) say ft-lbs. Like another member indicated, it seems to roll off of the tongue better.
