05-02-2013, 03:43 PM
#21
Originally Posted by mtnguy
Whoops. The correct term for torque is lb-ft, but many people (like myself) say ft-lbs. Like another member indicated, it seems to roll off of the tongue better.
I think we all do, but it is not technically correct. We all know what we're referring to tho'.
05-02-2013, 05:06 PM
#22
Originally Posted by thebrakeman
ft-lb or lb-ft, same thing. There may be a standard convension, but they both mean the same thing, neither of which is a unit of power.
Horsepower is a unit of power, and is never stated in terms of ft-lb or lb-ft (which are units of torque).
The amount of power is expressed as so many "horsepower", or "hp", or some other unit of power (watt, Btu/hour, etc).
Exactly!
05-03-2013, 05:25 AM
#23
I have 1/4" drive and a 1/2" drive both from Harbor Freight.....checked both against a snap-on....just as accurate and both cosh $9.99 each.
05-03-2013, 06:17 AM
#24
I just added two torque wrenches to my tool sets.
I bought a 3/8 drive that goes to 100 ft lbs and a 1/2 drive that goes to 250 ft lbs.
I shopped some and was willing to settle for solid performance without going to the high end unnecessarily. I ended up with Kobalt. I got mine from Lowes you may find them cheaper on Ebay, etc. They come with a lifetime guarantee.
The 1/2 drive was about $80; the 3/8 was about $60 but I don't recall exactly.
I've used both now checking the antisway bars on the Ford chassis and other applications, and they work just fine.
Roll
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2018 Wrangler Unlimited Sahara (JKUS). Many upgrades, additions, mods, and changes to the coach.
05-03-2013, 07:03 AM
#25
Originally Posted by Chfranco
Bought a propride 3p. Sean recommended using a torque wrench for install. I don't own one. Does anyone have a recommendation?
If you need one over 150# rent one for 1 time install. Buy a cheap 150# one to keep in your T/V for flat tire use on your T/V and towed R/V. Also include a short ext and sockets to fit T/V and towed unit,it makes removal of wheel nuts easier than the tire irons that come with the units. This is for trailers,if you have a (A,B,C,D,or some 5th wheels) you will need a Bigger torque wrench! Youroo!!
05-07-2013, 12:01 PM
#26
Originally Posted by OldCoot
Right. "foot-lbs per second" is a unit of power.
But in your previous post, you said only ft-lb (or lb-ft, I forget).
This explains why you can calculate hp by dividing torque by rpm (then multiplying by some constant, 5252, IIRC).
ft-lbs is torque
ft-lbs/sec is power
hp is also power
05-08-2013, 07:13 PM
#27
if I need a tq wrench I just get one from work. we have about 40 from 5inch lbs up to 2500ft lbs
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
05-08-2013, 07:18 PM
#28
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
