Old 06-27-2015, 09:01 PM   #1
Tow bars E4 Hitch?
I have an E4 hitch rated for 10Kmand the bars 1K tow weight. How do I know they are enough for my camper?
282RK Heritage Glen, 6850 dry, hitch 700 lbs.
Ford F-150 tow wt 11,100, hitch weight 1100, 3.73 axle, max tow package 1680 payload.
They gave me the E4 hitch with 1k bars. The camper is 34 feet and the truck is 21 feet. I have no trouble towing it but I noticed some wind effect on the rear end of camper. Is it because of the length?
Scorn is offline   Reply With Quote
Old 06-28-2015, 10:55 AM   #2
You should go through the weighing process to figure out your actual tongue weight and how much front axle weight is being returned to the front axle. Your hitch may not be set up correctly. Feeling some push from wind is normal. Even if it is set up correctly the first couple of windy days you will feel uneasy, i know I was.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-29-2015, 04:24 AM   #3
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Thanks, I will check that out.
hitch
