Old 08-23-2016, 10:03 AM   #1
Tow capacity clarification
just for clarity can anyone walk me thru what the tow capacity of my truck should be? 2008 F150 Lariat 5.4 l tow package 3.73 rear end.door sticker shows GVWR 7200lbs frontGAWR 3900 rear GAWR 3850 275/65/18 tires at 35 psi.Currently towing 27 Shasta Revere 5436 lbs dry weight but these weight stickers on my TT have been recalled for being inaccurate.Unable so far to get Forest River to give me actual accurate weight. scales to weigh uncommon in my area.advice on towing capacity or probable true weight of unit much appreciated Thanks
mulher is offline   Reply With Quote
Old 08-23-2016, 10:08 AM   #2
Hermes1's Avatar
Do not see the door sticker, but it tells you the tow capacity of your specific truck as it was built.
Regards, Bruce
Current TT: Northwood Snow River 246RKS
2015 Ram 3500 DRW Cummins Diesel w/AISIN Tranny
Hermes1 is offline   Reply With Quote
Old 08-23-2016, 10:17 AM   #3
Flybob's Avatar
Important number is max cargo capacity ( on Drivers door sticker) . Subtract from that passenger weight, 100 lbs for hitch, and weight of any cargo in TV. The number you have left is the max tongue weight. So max loaded trailer weight is approximately that number divided by 0.20.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-23-2016, 05:52 PM   #4
CWSWine's Avatar
You can get you payload ratings off your yellow sticker on your door post and put in the first blank and estimate the rest of the numbers and you will have the max weight you can tow. I guess I should add - and say within your trucks manufacture specs.
Towing Calculator based on Truck's Payload/CCC - Towing Planner
Matching you truck to your RV....
http://rvsafety.com/rv-education/mat...ks-to-trailers
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 08-24-2016, 07:52 AM   #5
raspivey's Avatar
https://www.fleet.ford.com/resources...TTgdeSep08.pdf
Old 08-24-2016, 10:23 AM   #6
CWSWine's Avatar
Deleted
cat
