Tow Dolly Hitch Issue
Adrinkard, we use an electric brake Stehl dolly behind a 32ft class C towing a Caddy SRX. Set at the recommended ball height, the "V" shaped support under the tongue drug so often going in and out of gas stations, etc., that the bottom of the V wore all the way through in 6000 miles. It was hitting instead of the motor home frame skids. This was with a 3 1/2" drop. I changed the ball mount to a 1 1/2 drop flipped over to provide + 1/2". Have driven 800 mile this way without any more problems. The ball is 4" higher and there is still plenty of ground clearance between the back of the dolly ramps and the ground. Now that we are back home, I need to swing by a welding shop and get the "V" put back together. Hope this helps you.
Gary
2017 SunSeeker 3010DS
