Tow Dolly Restrictions
New RV owner and first time ABOUT to use a tow dolly.
My drive way slopes, so there is no way to connect the dolly to the hitch. I can do it, if I lift it up high enough but the tow dolly tires would be in the air. Obvious solution is to move everything to a level spot and hook it up.
My question is, what if I'm driving and I encounter some similar steep angle? Is the tow dolly going to bottom out? Is there some modified hitch that I need that lowers the dolly closer to the ground? Or is this simply just because a drive way will have unusual inclines that I don't need to worry about on the road?
Steve
