08-13-2018, 03:50 PM
Tow/Haul
When you tow your TT or 5th wheeler do you engage tow/haul on your truck?
08-13-2018, 03:52 PM
I do. I like the way the trans shifts.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
08-13-2018, 03:53 PM
RV There Yet?
Every single time. On our 2009 F150 it holds the shift points longer and also activates downshifting on grades by tapping the brakes. there seems to be less hunting in the transmission. i figure that the engineers are a lot smarter than me and put it there for a reason so i had better use it. plus, it tows like crap without it engaged.
08-13-2018, 03:55 PM
I changes the shift points but I like it to use the engine braking when it downshifts when you apply your brake on a downgrade. Of course in Florida you don't have a chance to experience that but it will do it if you brake hard on the level also.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
08-13-2018, 04:05 PM
Originally Posted by IsleDog
... i figure that the engineers are a lot smarter than me and put it there for a reason so i had better use it. plus, it tows like crap without it engaged.
X2, that's exactly why I use mine. Towed once when I forgot to engage it and it was a terrible pull until I realized my mistake.
08-14-2018, 02:33 AM
I use it. For my Silverado, using it is recommended when total weight is more than 75% of max gross combined weight.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
08-14-2018, 05:26 AM
I use it, lesson learned years ago. It might be different with newer transmissions but years ago I was told tow/haul or the old O/D off, turned the overdrive part of the torque converter off. Leaving it on caused the torque converter to shift excessively causing heat build up and damages transmission when towing.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
08-14-2018, 05:50 AM
Yes, always. Had an older truck that was 3 spd with overdrive and ran in overdrive. Our 400 mile trip ended at 90 miles when the transmission boiled out.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
08-14-2018, 06:11 AM
"On the road again"
Every time...before I put it in gear. Just a habit I started with our 2010 F250 and continue today with our 2017 F-350...for all the reasons given previously.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
08-14-2018, 06:36 AM
Absolutely, my Ram tows like a champ with tow/haul activated.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
08-14-2018, 06:53 AM
(Dry Huunday)
Yes.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
08-14-2018, 07:23 AM
That’s why it’s there, so a yes from me!!!
Current:
2019 Rockwood Roo 24ws
2016 Chevy Silverado Z71 4x4 DC
Past:
2001 Starcraft Spaceliner PU
1987 Starcraft Nova PU
08-15-2018, 02:24 PM
Yes! As mentioned Tow/Haul changes shift points and assists with braking on down grades. Save your brakes, use tow/haul.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
2018 25 2019 25
2020 24 2021 28 2022 302023 30
08-15-2018, 02:27 PM
Of course, that's why it's there!!
2019 Silverado 1500
No camper, currently
08-15-2018, 02:46 PM
Gold Tee Box
I guess I'm the contrary one, an say NO, never used it. We have plenty of truck for the load, and engine braking if needed.
Tow/Haul causes high engine revs when not needed. I may only use it when at steep inclines starting out, but that's what 6 speed transmissions are for, unless you're heavily loaded.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
08-15-2018, 03:10 PM
I'm Lost
X3, all the time.
G
Geoff, Francesca and Lucy the Golden holy terror (I mean retriever, BD Nov. 2018)
2023 F150 Screw, 3.5L, HDPP, LT tyres.
2013 Rockwood Signature 8310SS
2023 F150 Lariat 502A (After all rebates, price protection and dealer discounts, I saved $12,600Cdn. (Cavalcade Ford). If pays to shop dealers! (April 2023)
08-15-2018, 05:21 PM
Always tow in tow/haul, very helpful on steep down grades.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
08-15-2018, 08:28 PM
I use it religiously. I find that even though it rev's higher with higher rpm shift points that my EGTs are lower which I feel is better for turbo versus higher engine revs.
I often use it driving unloaded in high mountain areas because it does a great job maintaining speed down the steeps.
08-15-2018, 08:35 PM
If I'm towing or hauling, I use the Tow/Haul function.
The exact function differs from manufacturer to manufacturer and from year to year for the same manufacturer.
08-15-2018, 08:39 PM
We used it when driving through the west on a 35 day trip (Glacier, Rushmore, Badlands, Yellowstone, Park City, Colorado). Lots of elevation change and a couple steep downhill sections (8% grade). It worked great. However, when hauling across South Dakota, I just kept the truck in normal mode and it worked fine also.
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition
2018 Cedar Creek 36CK2
