Old 09-05-2012, 09:45 AM   #11
camper_Lucy's Avatar
On a Chevy Allison (at least) it will lock the TC and increase the pressure which provides a lower operating temp.
Besides reducing your fuel mileage at higher loads it will save on your brakes as well.
Keep in mind the Cummings Tranny is an entire different animal
Right from the 2011 Chevy Owners Manual:
Tow/Haul is designed to be most effective when the vehicle and
trailer combined weight is at least 75 percent of the vehicle's Gross
Combined Weight Rating (GCWR). See “Weight of the Trailer” under
Trailer Towing on page 9‑94. Tow/Haul is most useful under
the following driving conditions: . When pulling a heavy trailer or
a large or heavy load through rolling terrain.
. When pulling a heavy trailer or a large or heavy load in
stop-and-go traffic. When pulling a heavy trailer or
a large or heavy load in busy parking lots where improved low
speed control of the vehicle is desired.
Operating the vehicle in Tow/Haul when lightly loaded or with no
trailer at all will not cause damage. However, there is no benefit to the
selection of Tow/Haul when the vehicle is unloaded. Such a
selection when unloaded may result in unpleasant engine and
transmission driving characteristics and reduced fuel economy. Tow/
Haul is recommended only when pulling a heavy trailer or a large
or heavy load.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 09-05-2012, 10:37 AM   #12
lindy's Avatar
With my Dakota I always use the tow/haul mode whenever I'm towing the camper. Just seems to put a lot less stress on the trans with the changed shift points, and the motor doesn't work as hard.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 09-05-2012, 11:50 AM   #13
Camper Less Camping
Cajun Po-Boy's Avatar
or heavy load.
Ditto, I use it always with camper
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 09-05-2012, 12:04 PM   #14
TeresaInCAL
TeresaInCAL's Avatar
I always use it because that's what it says to do in the manual.
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
TeresaInCAL is offline   Reply With Quote
Old 09-05-2012, 12:52 PM   #15
Dallas Texas
TexasBBQ's Avatar
90% of the time I use it. It keeps my trany, AF, and oil temps down. If I see a long flat highway ahead I'll turn it off to help the MPG. But, if I have a strong headwind on a flat I'll keep it on.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 09-05-2012, 01:13 PM   #16
Mark and Linda's Avatar
I use mine...still trying to figure out when I get the best gas mileage. Going to find out in the next few days...going to tow over Monteagle on I-24 about an hour's drive away. Also...Chevrolet owner's...do you access your vehicle's manual online?
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 09-05-2012, 01:48 PM   #17
I tried it last weekend and didn't care for how it acted. It's pretty flat around here so I'll try it again at the end of month in the hills up north.
Len & Cheri is offline   Reply With Quote
Old 09-05-2012, 01:53 PM   #18
ironj's Avatar
Originally Posted by EdJunior
I use mine whenever I am towing my 5th wheel (except when I stop and forget to engage it again!). As noted above, it activates the engine braking in our F-250's, and does all that other stuff. But it only shifts when needed. Since mostyou of my towing is on the flatter areas of Texas, it makes no difference in mileage for me, since my tranny stays in 6th gear once I get cruising. I think that holds for most with the tow/haul as well. If it's staying in 6th gear (or that highest gear for your truck/tranny), mileage is probably not affected much, if at all, and it will give you the engine braking if needed.
you know , a couple of times this last week end I stopped the truck, and got back in to go and tow/haul was still on when I started truck????..normally it turns off when I turn truck off?.....hmmmm
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 09-05-2012, 06:55 PM   #19
Now a "Top Member"
EdJunior's Avatar
Really? Hmmm, maybe an update to the 2012's?? Interesting!
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 09-05-2012, 09:18 PM   #20
So... are some here trying to believe they're smarter than the engineers and mechanics who built and designed these trucks?
If the manual says to use tow/haul mode when towing or hauling why would you think that it's not the right thing to do?
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
cummins, dodge, tow mode
