Old 09-09-2012, 08:34 PM   #41
dunnnc,
How fast do you normally tow your rv? I stay at 60, if overdrive does not kick in until 60 I will tow at 55 next time.
daavalanche is offline   Reply With Quote
Old 09-09-2012, 08:52 PM   #42
Mark and Linda's Avatar
Mine seemed to do better when I was doing 55 today...will check it again on the way home next week.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 09-09-2012, 08:52 PM   #43
Originally Posted by daavalanche View Post
dunnnc,
If I'm on flat lands, around 62-65 so it will engage OD. If there are rolling hills, I will stay between 55 & 60 and it will not go into OD. While in Tow mode, it will not shift into OD if there is any load on the engine at all. Sometimes I might get to 65 before letting up on the accelerator and let it shift and then very gently apply the throttle. We are usually always between 55 & 60. Rpm is around 2000 -2100 around 60 out of OD and around 1700-1800 in OD at 60.
Old 09-13-2012, 10:48 AM   #44
Sorry gang, late to the thread here and got lost. I have an 08 mega cab 1500 that has a tow/haul button. Push once = tow/haul. push again = overdrive off. Do I understand this right that not only when pulling out of the parking lot and up hills, I should keep the tow/haul button on at all times while towing my 5ver down the side streets, Highway and campground ?
Mike - Ottawa
'10 Rockwood 8280ws
2014 Ram 2500 SLT HD Crew Cab 4X4 3.73
Mike101 is offline   Reply With Quote
Old 09-13-2012, 11:21 AM   #45
Wanna Be Camper
SaskCampers's Avatar
I always had our Megacab in tow/haul with either the V-Lite or my flat deck with 8k of water. It shifted firmer and was quicker to change to a lower gear on hills as well as holding gears longer.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-13-2012, 11:35 AM   #46
I was using only in tough times (hills) and then off. Heading to Picton wine country Friday morning. Will tow haul all the way and see how she does. Thanks.
Mike - Ottawa
'10 Rockwood 8280ws
Old 09-13-2012, 01:32 PM   #47
Coops1's Avatar
The other benefit is a cooler engine due to the higher rpms
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 09-13-2012, 06:55 PM   #48
Now a "Top Member"
EdJunior's Avatar
You're only going to get the higher RPMs if the tranny downshifts. Unless you mean when you lock out the overdrive. But if the truck is pulling the trailer with no stress, it will run just as cool in overdrive as any other gear. The tow/haul in these new trucks are smart enough to know when to shift, and when to let you cruise along. Trust them, and use them.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 09-13-2012, 09:49 PM   #49
transamz9's Avatar
My tow/haul holds OD longer and it also lets the TC lock in 3rd gear.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 09-14-2012, 12:32 AM   #50
Coops1's Avatar
When in tow/haul I see slightly higher rpm's, (maybe 150) and with my Edge Insight I see lower egt's compared to not having it on.
Tow/haul does not lock out overdrive with the allison.
The Allison 1000 Series 6-speed automatic transmission used with the 6.6L V8 Turbo Deisel has a Tow/Haul mode that engages the Torque converter clutch in second through sixth gears, which reduces heat buildup that an unlocked converter can generate when under heavy loads. It also enhances the "Grade Braking" feature.
Take note: this is not the overdrive lock-out used by many competitors. In fact, Tow/Haul mode, combined with Passive Shift Stabilization, permits towing in overdrive for optimum fuel efficiency in most situations. The Passive Shift Stabilization feature detects and reduces a condition referred to as "shift busyness."
26WRB - V-Lite
Denali HD LML
cummins, dodge, tow mode
