Old 06-29-2015, 11:16 AM   #1
iluvlcy's Avatar
Tow mode question
We tow with a 2003 ford expedition, no tow mode but manual says when towing turn overdrive off. With it off when going up hills it downshifts and rpms go to about 3600, on our last trip we left overdrive on and when going up hill no downshift and rpms stayed at about 2500 and it just felt and sounded better, like it wasnt working as hard. We also went from 7 to 6 miles per gallon. We are not mechanics and do not know what overdrive really is? Are we overworking something by leaving it on?
Pam
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 06-29-2015, 11:22 AM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
If you are encountering grades where the truck will continually down shifts you could over heat the trans and cause damage. Go with the manufactures recommendation. You are causing the trans to work harder by not removing from overdrive. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-29-2015, 11:26 AM   #3
iowasparrow's Avatar
The overdrive gear is a pretty small ring in relation to the other gears, you will burn it up over time pulling in overdrive.
iowasparrow is offline   Reply With Quote
Old 06-29-2015, 01:50 PM   #4
Trust me, that drop in fuel mileage will be a lot less than a transmission replacement. It is better to keep the RPMs up a little and have less down shifting, hence overdrive off when towing. This is why the manufacture says keep it off when towing.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
modifications
