Old 11-05-2011, 10:05 PM   #11
TTNewbees's Avatar
Sounds like a good time!
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 11-05-2011, 11:02 PM   #12
Taranwanderer's Avatar
Originally Posted by CliffP View Post
In 1976 my parents ordered a Olds Cutlass Supreme station wagon with a 455, put air adjustable shocks on and used a weight distribution hitch (no sway bars then) to pull a 28' stick and tin tank of a camper from WI to OR and the long way home with no problems. Now my 1/2 ton isn't "heavy enough" to pull a lighter camper. Hmmmmmmm?
You can thank all the CARB regulations and the never-ending EPA mandates for more fuel efficient (and therefore lighter) vehicles. More government intervention in our lives, folks, and it's only going to get worse.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 11-05-2011, 11:34 PM   #13
2007 WildCat 32QBBS
05CrewDually's Avatar
Higher torque from a 455 made it possible getting about 7 miles to the gallon. I wouldn't tow anything but a small boat with a little half ton p/u. Nothing beats the stability of a dually.
05CrewDually is offline   Reply With Quote
Old 11-06-2011, 05:36 AM   #14
dretired's Avatar
When looking at what a "loaded " F 150 ecoboost crew cab will cost.... .3.5 engine , max tow pkg, Max payload pkg (8ft box) in a XLT or Lariat model..4x4 ?? or not... at least a 3.73 rear axel.. you may well be in the price range of a F 250.. that should have 12,000 lbs of towing capability and 3,000 lbs of payload capacity
dretired is offline   Reply With Quote
Old 11-06-2011, 07:28 AM   #15
MtnGuy's Avatar
Originally Posted by Dave_Monica View Post
I
I don't think you're going to get the support you're looking for in your decision to be pulling a 34'10" camper with a 116" wheelbase Denali. The dry weight of this camper is probably understated at 7098 lbs...the real dry weight is probably closer to 7500 lbs. It shows a carrying capacity of 2500 lbs so it's GVWR must be in the range of 9500 to 10,000 lbs.
I don't know if this was a case of listening too much to the salesman, but clearly that is too much camper for your Denali.
What Dave said !!
I have tried to stay away from being the length and weight police recently, but that combo has brought me back into the mix.
IMHO, a 116" vehicle should not be pulling a 35' conventional travel trailer. A 23 footer with the proper setup....yes, but not something way over 30.
And I would forget about a 1/2 ton truck to replace the SUV. With a listed tongue weight of 953 lbs., that figure is going to be in the neighborhood of 1200 lbs. camping ready. That tongue weight is going to exceed many 1/2 ton hitch ratings, as well as maxing out the GVWR of 1/2 ton trucks. Yes, you may be able to stay under the GVWR with the trailer only, but load the family and some gear in the truck and I betcha it will be over the max.
A big engine, low gear ratio (high number), long wheelbased 3/4 ton truck is needed for that trailer.
If you weigh the Denali with the trailer hooked up, camping ready with all passengers in their seats, I believe you find that you are way over the GVWR of your SUV.
Old 11-06-2011, 07:39 AM   #16
Dave_Monica's Avatar
Originally Posted by TTNewbees View Post
Yukon XL 130", 143" on silverado hd 2500, obviously makes a huge difference.
I missed the fact that your Denali is an XL at 130" wheelbase rather than 116" and I apologize.
I wouldn't, however, change my opinion in regards to it's suitabilty to tow your camper.
Dave
Old 11-06-2011, 07:55 AM   #17
MtnGuy's Avatar
Dave
I will stay with my post, also. With a 130" wheelbase SUV, a 26' travel trailer should be about the maximum length. The LaCrosse weight also remains a problem.
Old 11-06-2011, 08:24 AM   #18
Agreed, we will try it and if needed downgrade our tow vehicle. None of it still makes any sense to me but I am not an engineer. Comments so far are on wheelbase. Yukon XL 130", 143" on silverado hd 2500, obviously makes a huge difference. May have to get a 3.5 l ecoboost before next summer, gives me a reason to go to auto show.
Thanks!
When you are coming down that mountain if you want a cast iron block engine, heavy duty transmission, heavy duty frame, heavy duty brakes and a full floating rear axle (all designed) to absorb all that stress then get a 3/4 ton pickup. If not get a 1/2 ton. There is more to consider than just tow rating.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 11-06-2011, 08:30 AM   #19
GASPEDDLER's Avatar
Very good point.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is online now   Reply With Quote
Old 11-06-2011, 10:42 AM   #20
TTNewbees's Avatar
Now we need a dually, lmfao! I am definitely limited in experience when it comes to towing a TT, however at 41 years old I have been towing boats and four wheelers since 2mos of my 16th birthday, so have some experience. I think the small boat thing is way over the top, I pull my tandem axle, 5000 lb boat through the ozark mountains at 80mph blowing by that dually.
Thanks for the realistic replies, and the weight issue has confirmed my thoughts. I will weigh the whole setup on my way to Tennessee and if we are borderline and tv struggles I will look at getting a 2500 suburban or truck b4 next summer. (probably not a dually though, the wife may struggle getting that into the parking garage at work.)
Mike
2012 Lacrosse 303RK
