Old 11-06-2011, 01:03 PM   #21
Dave_Monica's Avatar
Originally Posted by debbilicious View Post
I'm purchasing a 35' 5th wheel with a dry weight of 9644 lbs and a hitch weight of 2020 lbs. I'm looking at purchasing a Chevy Silverado 3/4 ton, Diesel with Ally tranny. My research so far tells me this: "The 2500HD ups these ratings to 16,100 pounds (7,300 kg) with the 8.1 liter engine or 10,600 pounds (4,800 kg) with the 6.0 liter engine, and 4,058 pounds (1,841 kg)"...I don't know what all that means really, so is the "horse" big enough to pull my "cart"? ; )
Moderators...
Perhaps you could re-post this as a new thread.
Dave
Old 11-06-2011, 04:46 PM   #22
MtnGuy's Avatar
Originally Posted by Dave_Monica View Post
Moderators...
Dave
Good suggestions....done deal.
Old 11-19-2011, 05:43 PM   #23
TTNewbees's Avatar
Well first big test, no issues. Drug it around in 30mph winds up and down the hills, no issue. Of course smokey mnts ain't no Jackson hole Wyoming. Hardest thing so far was getting cable to work. Turn off power boost for antenna then they came in. Of course no manual to tell me that!!
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 11-19-2011, 07:04 PM   #24
Location: No longer own a Forest River product, but enjoy the info on this site
Hi Mike
From edmunds.com "Towing capacities for the standard Yukon XLs range from 7,100 pounds on the 1500 2WD to 9,700 pounds for the 2500 2WD."
Does your Dinali have leather seats? If you tow a camper that is overrated for your tow rig, you'll most certainly notice butt cheek bite marks in your leather seats. If you can tow without driver related stress based on your towing conditions you may not need a larger tow vehicle... (i.e. putting down the road to the local campground.)
On a completely unrelated note - a salesman is a tool that works for you, the buyer - not the other way around. Knowing what you want before entering any discussions will result in a purchase decision that meets your needs - not their sales quota.
MTNGUY's feedback seems to be worth your consideration.
Good luck and best wishes in your travels.
Darren
teamgl is offline   Reply With Quote
Old 11-19-2011, 07:57 PM   #25
TTNewbees's Avatar
Thanks, not sure what u r saying but I am good and comfortable with the existing set up battled 35mph crosswinds thru the hills with 0.0 issues. Fully loaded. My 6.2 liter Denali is flat out a beast, has a 1 ton transmission air ride, would a 2500 diesel be better, absolutely but without a 3rd row dog needs a kennel which is not in the cards.
Mike
2012 Lacrosse 303RK
Old 11-19-2011, 08:05 PM   #26
TTNewbees's Avatar
Probably the biggest issue I have is not load or tow related, it's compartment doors falling off. Further investigation shows crooked screws everywhere. This thing is loaded with storage, so lots of screws falling out everywhere.
Mike
2012 Lacrosse 303RK
Old 11-20-2011, 09:40 AM   #27
Sgt. Schultz's Avatar
Mike - not sure if you went through the GMC specs for your truck (attached) or available here:
http://www.gm.ca/media/vehicles/comm...rochure_EN.pdf
With your Lacrosse being on the large & heavy side of TT's (Prime Time Manufacturing, Manufacturers of travel trailers and fifth wheels) You are going to want to be sure you are within the manufactures' set legal limits for your truck, (see calc at Travel Trailer Weight Calculator ) & know how to set your hitch especially if you have the Autoride suspension (unique steps) it will go along way towards peace of mind when on the road with your family.
cheers
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 11-21-2011, 06:38 PM   #28
TTNewbees's Avatar
Thank you, and I did review the specs. I can only say that the truck hasn't hicupped going through the hills at 65-70mph and hardly an inch of sway. When hitched it takes a minute for the truck bags to bring everything level. I will say, these are the smoky mtns not Jackson hole, so that can all change.
Mike
2012 Lacrosse 303RK
Old 11-27-2011, 02:31 PM   #29
Vols's Avatar
2011 Ram 1500 Sport 4x4 Crew Cab (3.55 gears)
2012 Tracer 3150Bhd
Pulls & Stops like a champ!! Only truck mod is Timbrens which made a world of difference in bounce.
Zero sway , I try n keep between 55-62 mph. Avg 9-11 mpg depending if hills or head wind.
We did not plan on trailer when bought truck but Thank God it's worked out for Great for us!!!!
Vols is offline   Reply With Quote
Old 11-27-2011, 03:50 PM   #30
TTN, don't forget that when you go out west into the high country, you will be losing a LOT of power with the increase in altitude. Your Denali may be a "beast" around home, but the mountains can turn it into beast doo-doo.
