Old 02-06-2014, 10:49 PM   #21
Rrickim63's Avatar
Agree with above. Lower revs don't equate to lower temps.
Sent from my LG-LS720 using Forest River Forums mobile app
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 02-06-2014, 10:52 PM   #22
Do you have a 'fuel economy' setting on your instrument cluster? You could reset that once on flat highway in OD and travel a few miles, then lock out OD and reset your fuel economy and see how it compares to the other. I have a diesel engine and checked my fuel economy pulling my trailer and found fuel economy better when I locked out 6th gear and travelled in 5th gear. The engine wasn't working as hard with the weight and wind resistance. Something for you to try and hope that gives you some peace of mind towing.
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
wingriders is offline   Reply With Quote
Old 02-07-2014, 12:25 AM   #23
Check the manual about towing, it may state specifically if you can or connat use it, being a van and not a truck, I would be inclined to think not.
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
Old 02-07-2014, 01:20 AM   #24
puff's Avatar
Do as you like but most if not all manuals I have seen regardless of truck or ??? stat NO towing in O.D. Lower RPM's turn water pump slower turn oil pump slower turn fan slower turn power equipment slower which means less coolant moving means hotter coolant less oil flow slower fan means air movement is less adding more heat. These same principles apply to fluid from your tranny to the rad as well and those temps go up also.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 02-07-2014, 06:51 AM   #25
ironj's Avatar
The tow\haul on mine has no impact od...temps are stable even towing in 100+ ambient temps?...nor does the owners encyclopedia say NO towing in Od....you can however lock out ANY Gears you choose independently of using the tow/haul button?
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 02-07-2014, 02:20 PM   #26
puff's Avatar
[QUOTE=ironj;538426]The tow\haul on mine has no impact od...temps are stable even towing in 100+ ambient temps?...nor does the owners encyclopedia say NO towing in Od....you can however lock out ANY Gears you choose independently of using the tow/haul button?
Iron that may be well and true for your Full Size Truck with a monster diesel engine but we are looking at a Dodge Caravan doing the pulling.
Ultimately the choice of what I can pull, is it too heavy, am I at my max weight, can I safely pull this RV, can I stop it if my brakes failed, am I putting my family at risk are questions every owner must at some time ask themselves. I am sure everyone here, including myself have seen some questionable setups and laughed or at least shaken their head at.
I think I would be asking the Chrysler Mechanic what he thinks and go from there. The salesman will tell you anything to get the sale or make a new one.
I hope you get the right answers..!
Old 02-07-2014, 04:08 PM   #27
acadianbob's Avatar
I don't know if there IS one right answer regarding transmission strategy. Vehicles may behave differently. I will say that my F150 transmission runs at 195 degrees; whether towing or not. The gear that I run in doesn't make any difference; speed makes no difference; outside temperature makes no difference. It will climb a few degrees on a long, hard climb on a very hot day. But your vehicle may perform differently. . . .
To me the keys are: 1) make sure your engine is in the powerband it needs to pull the load 2) make sure your transmission is "hunting" for the right gear. If it is constantly upshifting and downshifting; go down a gear.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 02-07-2014, 06:23 PM   #28
ironj's Avatar
[QUOTE=puff;538617]
You specifically said "truck"...so I thought u meant all trucks (I dont consider a mini van a truck...lol)...
In the end regardless of where the button is or gear that trannys life is gonna be either shortened or require a lot of maintenance more than likely....
All comes down to what the op is comfortable with....not like a good majority of members here arent way over loaded regardless of vehicle....
Old 02-07-2014, 06:58 PM   #29
Carknocker Family
Ida Ratherbe Camping's Avatar
I feel like a couple of trips and the OP will answer some of his own questions. Will probably start looking for a heavier TV. I pulled a pup that weighed 1800 dry will a Nissan Quest. It would do it, but not very comfortably. IMO
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 02-07-2014, 07:29 PM   #30
Crusadernoob's Avatar
Not real sure on your minivan, but as far as most vehicles I work on the electric fans usually kick on around 230F this is normal operation. Trans temps will usually be 100F over ambient with a good cooler, the problem will be you will be towing very heavy with that vehicle, maxing out everything. You will see hotter trans temps with hotter coolant temps due to the fact that your trans fluid will be getting hotter and hotter due to the fact that your trans fluid runs through your radiator, and if you are lucky through an auxiliary trans cooler, over time they won't keep up, you will absolutely need to change out your fluid much more frequently for any kind of longevity. My TV temps won't even come up to operating temp till I drive for 30 minutes, I actually restrict my air flow (across my radiator only) to maintain 200-215F ECT and my trans usually falls in at 150F most engines like warmer ECT but you need to be able to control it.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
