Old 02-08-2014, 10:09 AM   #31
VicD's Avatar
We drove approximately 75 minutes yesterday. Coolant reached around 205, which is normal. Transmission peeked around 185 in traffic, but settled down to 165 on the highway. Didn't do O.D. Quick braking on wet roads, too, which was a surprise. So far so good.
--Vic, Clermont, FL
2013 Dodge Grand Caravan SXT w/ e2
2014 Coachman Viking 17BH
Nights Out YTD - 17 (6 Trips)
Travel Companions - DW, DS (5) & DS (1)
VicD is offline   Reply With Quote
Old 02-08-2014, 05:13 PM   #32
dsrace's Avatar
temps sound good and brakes must have worked good this time. if you plan on keeping the van get the trans flushed now with good synthetic fluid put back in it and change the factory external trans oil cooler. replace it with a heavy duty aftermarket one maybe with a fan on it for real hot days but for now temps sound good. if your even thinking of replacing the tow vehicle but want the capacity of the van look at excursions or suburban's and look for the 3/4 ton ones! regardless of what others may say 3/4 ton is no rougher than 1/2 ton with good shocks.
'99 f350, quad cab long box, dually, 6 speed manual, gently mod'd.
2011 wolf pack 295 with full susp now!
dsrace is offline   Reply With Quote
Old 02-08-2014, 06:08 PM   #33
Crusadernoob's Avatar
Sounds good but just make sure to keep an eye on it when warm weather gets here, it makes a big difference when you got 95 degrees and 95% humidity, a/c kicking. I would also suggest synthetic trans fluid also, if you got a lot of miles give the cooling system a good flush and blow out the cooling stack also, you would be surprised how much debris will come out of it.
2006 2500HD Duramax CCSB 2WD
2014 Crusader 285RET
Nights camped in 2013 - not enough!
Nights camped in 2014 37
Nights camped in 2015 40
Nights camped in 2016 35
Crusadernoob is offline   Reply With Quote
