Old 02-04-2014, 10:11 PM   #1
VicD's Avatar
Tow Questions
I have a few questions about towing that I'm looking for some "real world" guidance on. I can google anything, but this group is valuable because you are 'doers', not just 'talkers'. Anything is appreciated.
1) Should I tow my trailer in overdrive or should I turn off overdrive? I recently read something that makes me question this. I assumed overdrive was the way I would tow for fuel efficiency, and I assumed the lower RPM was better for the transmission. Am I incorrect?
2) I am using an app called Torque Pro to monitor coolant temperature and transmission fluid temperature. Does anyone know the normal operating temperatures for these systems? I can set a high/low alarm, but I'm not sure where to set them.
3) The tongue weight on my trailer is heavy, 407 lbs. Should I make any modifications to my suspension, or how can I determine that? If so, any suggestions? I have a local shop that I trust to do the work, but I trust the advice from this group because of the vast experience here.
Thanks for whatever guidance you can provide - I appreciate anything at all.
--Vic, Clermont, FL
2013 Dodge Grand Caravan SXT w/ e2
2014 Coachman Viking 17BH
Nights Out YTD - 17 (6 Trips)
Travel Companions - DW, DS (5) & DS (1)
VicD is offline   Reply With Quote
Old 02-04-2014, 10:13 PM   #2
ironj's Avatar
what vehicle??
my f350 will tow up a hill in 6th gear (overdrive on) it depends on where YOUR engine makes power..
as far as temps, what vehcile...they all have diff specificatios...
and as far as tongue weight? what vehicle? are you using a sway control? what are you towing?
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 02-04-2014, 10:28 PM   #3
keith4216's Avatar
read the sig
keith4216 is offline   Reply With Quote
Old 02-04-2014, 10:45 PM   #4
Fulltime family RVer
Originally Posted by keith4216 View Post
read the sig
The new app doesn't show signature lines.
From the OPs signature line:
-- Vic
Clermont, FL
ependydad is online now   Reply With Quote
Old 02-04-2014, 10:58 PM   #5
Is your (Grand Caravan) what they used to call a(Mini Van)?Youroo!!
Old 02-04-2014, 11:09 PM   #6
2013 Dodge Grand Caravan SXT | Luxurious Family Minivan | Dodge
Old 02-04-2014, 11:14 PM   #7
ironj's Avatar
read the sig
What ependydad said. :-)
I have a tapatalk app
A frf forums app
And a web based browser...
Depending on which office im working out of I use diff apps..
Anyway, I know absolutely nothing about mini vans...so I relinquish any further comments to those who do!.
Safe camping and at least your asking for answers to your setup!...good luck!
Jeremy
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
Old 02-05-2014, 05:26 AM   #8
Rrickim63's Avatar
I've had a minivan before and recommend OD off. But, since you have a way to monitor temps, try it both ways. I would be more concerned about your tongue weight on a minivan. I would hook up and do a trial run to see how much it squats down and how it feels.
2006 roo 23b
99 Silverado xtra cab with 4.8 and tow package
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 02-05-2014, 05:33 AM   #9
Rrickim63's Avatar
Just looked up your camper and it looks like a lot of camper for your tv. I wish you luck.
2006 roo 23b
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Old 02-05-2014, 06:24 AM   #10
Indymule's Avatar
From what little I know about the caravan, I would think you are right at max towing for that vehicle. Check the owners manual but I bet it recommends overdrive OFF (that is most common). I would also check what the manufacture recommends for tongue weight. I would also guess somewhere in the 400 lb range.
I don't know the exact numbers for the Grand Caravan, you need to check the manual.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
2017 Ford F350 Crewcab Dually Diesel
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
