Old 08-09-2016, 02:38 PM   #11
Retired Techie
Had overheating problems on my 04 Duramax in July on I 80. New fan clutch, radiator flush, new long life fluid and all is well
2005 Wolf Pack WP22-2016 Grey Wolf 26RR-Gone
2004 Siverado 2500HD Duramax
2013 Keystone Springdale 5r
1998 Honda Valkerie
2016 Camping 148 days so far
moligney is offline   Reply With Quote
Old 08-09-2016, 02:46 PM   #12
TandSH's Avatar
Good suggestions above. Also, replace radiator cap.
2017.5 Cedar Creek 34RL2
2016 Flagstaff 8528IKWS Diamond Pkg (For Sale)
2016 F-250 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 08-09-2016, 03:41 PM   #13
I would try a radiator flush. It could work and it will not cost much.
whj77372 is offline   Reply With Quote
Old 08-09-2016, 06:48 PM   #14
have a radiator shop check the radiator over. some times the fin material that is between the water tubes in the radiator lose contact with each other resulting in poor heat transfer. when this happens to enough of the radiator fins it can't reject enough heat to keep the engine cool.
Hope This Helps Tim
TimVWulp is offline   Reply With Quote
Old 08-09-2016, 08:56 PM   #15
donNjudy's Avatar
If it is only overheating going down the road and not when its sitting still. That means radiator is stopped up. It may need to be taken apart and cleaned or replaced.
donNjudy
donNjudy is offline   Reply With Quote
Old 08-09-2016, 08:57 PM   #16
Originally Posted by Louisiana Irishman View Post
Ok traveling toward Seattle right now just a bit east of Denver. I'm pulling my 02 Salem 28.5 with my 03 2500 HD Silverado. Over heats & dies this is after a new Thermostat & water pump
Stuck on RV spot in Hudson Co.
What's wrong...?
That's a bad sign. Give us more info. Gas or Diesel 2500 HD? Running a tuner? Did it overhead to the point of dying while towing? How hot did it get? Any codes or check engine light? Did this problem come on suddenly or has the truck been running hot anyway and just started to really overheat? Did this start IMMEDIATELY after the new pump and thermostat or were those done in an attempt to correct the overheating? Did you add cold water to the very hot engine when it overheated? Gas or diesel is the big question. Completely different diagnostic processes.
2006 Chevrolet 2500HD CCSB Duramax/Allison
Demco 18k Autoslide
2012 Puma Unleashed 356QLB toy hauler
Toys - CRF250X, CRF250R, CRF450R, CRF150F, TTR230, TRX250EX
rmoore0852 is offline   Reply With Quote
Old 08-10-2016, 06:00 AM   #17
Lots of good suggestions here. No one has mentioned a potential collapsed radiator hose. And any OBDII codes being displayed? Radiator have a history of regular service? Paper / plastic lodged in front of radiator?
Any other symptoms? Does the oil look like it may have water (fluid) in it? Any engine miss firing or loss of power?
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 08-10-2016, 07:22 AM   #18
Thanks fo information guys
Louisiana Irishman is offline   Reply With Quote
Old 08-10-2016, 10:44 AM   #19
donNjudy's Avatar
Please be kind and post the fix.
Thank You
donNjudy
Old 08-11-2016, 04:30 PM   #20
nomad297's Avatar
Did you get this worked out? I am interested to know what the problem was.
Bruce
heating, truck
