Old 08-11-2016, 09:15 PM   #21
Last thing done was rad flush & proper coolant filled to cold fill in plastic reservoir.
Learned to watch coolant level more often
Also when pulling older heavy trailer thru inclines "mountains " don't use AC while climbing open windows and if necessary turn on heater to drain heat off engine
Louisiana Irishman is offline   Reply With Quote
Old 08-12-2016, 04:31 AM   #22
nomad297's Avatar
These are all the things I had to do to my '04 2500HD until I replaced the bad fan clutch.
Bruce
Old 08-12-2016, 08:23 AM   #23
What another thing that could go bad!!
Old 08-12-2016, 11:03 AM   #24
Thanks fo information guys
More info from you would be nice. Gas or diesel engine? Was this happening before the water pump and t-stat were replaced? Was the radiator and/or the a/c condenser fins plugged with debris????
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
Old 08-12-2016, 11:54 AM   #25
Gas, I just need to keep proper coolant level & turn off AC while climbing
Works ok now.....thx
Old 08-12-2016, 11:59 AM   #26
donNjudy's Avatar
Enjoy your trip.
Thank You for sharing the fix.
donNjudy
donNjudy is offline   Reply With Quote
Old 08-17-2016, 01:51 PM   #27
Bruce mentioned the fan clutch. May be a good idea to check and replace if needed. When the fan engages on hi speed, it will sound like a tornado under the hood. If you were not hearing that then the clutch ma be toast.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 8 so far
DocGTO is offline   Reply With Quote
heating, truck
